2000 S-Type HID Retrofit
Old Oct 12, 2007 | 10:35 AM
mep's Avatar
mep
Default 2000 S-Type HID Retrofit
Hey All!
I know this has been brought up several times, but it seems like the information found/discovered was never mentioned.
The question about wiring from a halogen setup to HID wasn't documented and would like to know from those who did
this retrofit the wire pairing. The harness plug on the halogen seems to not include 4 wires that the HID needs. The colors
are light green, yellow, light orange, and light purple (or blue)/yellow. If anyone could hook me up with that info that would
allow me to finish my retrofit. Thanks!
Old Oct 15, 2007 | 11:25 AM
bigdreams05's Avatar
Default RE: 2000 S-Type HID Retrofit
Crap, I don't have personal experience with this, but search buddy. I guarantee that there is information out there.
Old Jun 19, 2009 | 09:51 PM
ohsigmachi's Avatar
I was going to help untill I saw 03Stype3L's bulb wattage, I won't lend a hand to the destruction of a Jaguar.
Old Jun 20, 2009 | 01:29 PM
l17led's Avatar
If you want to get the whitest light from your HID's you should buy 6000K bulbs. The number refers to the temperature of the light, the higher the temperature the bluer the colour, The lower the temperature the redder the light. http://en.wikipedia.org/wiki/Color_temperature
As for the wiring, I have'nt got a clue. I bought a kit for my car and it was basically plug and play, there were only two wires to connect to the original harness.
Old Jun 20, 2009 | 01:59 PM
ohsigmachi's Avatar
Originally Posted by 01Stype3L
Hey ohsigmachi. The 12000k stands for a color of the bulb. It's kind of purple. The lower the number the whiter it is. The bulb itself is 35W. You can check it out yourself. I would really use some help on this. Thanks
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWNX%3AIT
I know exactly what it means, and I think they are trashy and have no business on a Jag. Unless you want your Jag to look like a mid-nineties honda civic with a JDM/Bride/Mugen/blahblahblah HID retrofit kit so you can audition it for F&F 4...
Old Jun 7, 2011 | 12:25 AM
steadicam's Avatar
Sorry to hijack this thread. But I hope my experience doing the retrofit will help someone. I have been working on this project for some time now. It seems that a lot of people bypass the auto leveling system entirely and use aftermarket relays and ballasts. i am currently trying to do mine a stock as possible. The wiring diagrams a readily available from the JTIS and it seems the that the HID lights are wired to a different point on the GEM I am not sure why this is. Tomorrow I am going to see if the wire is there on the GEM end of the connector. As far as the relays I am using stock relays in the correct positions in the fuse box. What PIA to work on the underside of the fuse box. I replaced clutches with less effort lol. The relay is mandatory (1 for each side)because the startup current is very high (close to 8 amps for just an instant )then down 2.65 nominal that is per side. I would bet the xenons will not even fire because the starting current through the halogen system probably wouldn't stand the inrush and could damage something in the process. As for the leveling I have dedcided to go British and have built the switch mechanism that is used in the UK that allows the user to adjust the height of the lights as needed. i had to order the right type of servos to make the whole thing work but they were surprisingly inexpensive. Right now I have the bumper cover off the lights out the wiring for the cabin switch done and most of the harnesses finished. that said it looks like the car is being parted out. I hope to have some pictures to share with you all very soon.
Old Aug 13, 2011 | 03:06 PM
JamesFederer's Avatar
can you tell me how to properly fit the oem hid set into a non hid s type? i have the diagrams and everything but im wondering what wires need to be cut/spliced/grounded out. thanks so much
Old Aug 15, 2011 | 09:06 AM
Brutal's Avatar
The halogens are triggered(turned on) with switched battery power to the light. Hid units are negativly triggered. So your powered trigger + from the cars electrical headlight connector goes to a relay that will trigger the ground - circuit to the hid unit. Forget about auto leveling you need way more wiring and parts to make that function. I sell hid units complete headlight assemblies for $600 a pr with instructions on the conversion either here, or occassionally ebay, or do the installs myself
Old Aug 16, 2011 | 07:22 AM
Yeah, I've read a lot about this and I'm aware of the leveling. I just want them to work lol. When I read the wiring diagram it specifically has the black 11th wire of the grey hid connector (fh40-11) being grounded out. Is that all that needs to be done? It cant be that easy...how much for just the directions lol
Old Aug 16, 2011 | 08:14 AM
JagV8's Avatar
To avoid blinding others etc, over here it's illegal to fit anything but those fully equivalent to factory ones (so, auto-level, headlamp washers, specific HID assembly, etc) - there's a thread running on the UK forum right now, sort of head-on confrontation between those who don't care about others (or the law) and those who do.
Very like those who don't understand what fog lights are for......
bdboyle
Sep 16, 2019 05:58 PM
pino
Sep 26, 2015 08:05 PM
mikin
Sep 26, 2015 10:21 AM
zdrapec
Sep 25, 2015 05:49 AM
