2001 S Type Sunroof Reset HELP
Old Jan 18, 2015 | 12:54 PM
Cartierusm's Avatar
Default 2001 S Type Sunroof Reset HELP
I've searched all over this forum and all the instructions to reset the sunroof seem to be for 2002 and newer cars. I've got a 2001. I tied all the instructions I did find to no avail.
My switch has 3 positions. If you press forward and the roof is closed it does nothing, not matter how long you hold it. It seems pushing forward is the closed position. Then you can press UP on the button and that operates the tilt. Then if you slide it backwards that's supposed to open the sunroof manually. If you slide the switch backwards quickly and release that's supposed to open the sunroof automatically.
Can someone direct me to resetting the sunroof on my 2001? Thanks.
Old Jan 18, 2015 | 08:33 PM
clubairth1's Avatar
Community Influencer
Your Moon Roof is no different than the 2002 model.
Old Jan 19, 2015 | 01:32 AM
Cartierusm's Avatar
Weird then, cause following the instructions and holding the button in the closed position the sun roof does nothing. No matter how long I hold it. I'll keep searching.
Old Jan 19, 2015 | 01:56 PM
tbird6's Avatar
You may have a switch or motor problem?
Have you removed the roof console to use your DVM to check what voltage you are getting?
Old Jan 19, 2015 | 02:15 PM
abonano's Avatar
check relay or fuse associated with the sunroof.
Old Jan 20, 2015 | 12:01 AM
Cartierusm's Avatar
OK will do.
I guess I left a post that was ambiguous at best.
My sun roof works, sort of.
Press up on the button and tilt works fine. Slide back and the roof tilts back to position and starts to open, but only a little, if I keep moving the switch back it opens a little more, until finally open.
Seems as though maybe a bad switch.
toronadomike
Jan 22, 2026 10:13 PM
way2far
Aug 31, 2022 09:26 AM
Sprayall
May 30, 2021 08:13 AM
Sprayall
Sep 3, 2015 07:49 PM
dcvickers
Sep 2, 2015 06:14 PM
