2002 jag s type r supercharged
Old Dec 11, 2014 | 01:27 PM
wfrocket's Avatar
Default 2002 jag s type r supercharged
just rebuilt complete motor for a friend. Tried to start but no fuel or spark. has fuel to rail. has good compression could this be a ground issue to the computer HELP!!
Old Dec 11, 2014 | 01:30 PM
tbird6's Avatar
We will need more information. It could be anything at this point.
Start checking everything.
Old Dec 11, 2014 | 02:18 PM
JagV8's Avatar
Use OBD tool. Codes? Post 'em. None? Read sensors. All OK then you're chasing something like a flooded engine or cable left off.
Old Dec 25, 2014 | 05:35 PM
wfrocket's Avatar
Thanks for the response and suggestions. I resolved the problem from one of a past response on another question asked. .........I connected the battery cables for 5 min and it started right up. But now I have another problem, upon starting the engine the timing chains are noisy seemed to be upper chains. Knowing the conditions of the chains and tensioners I pulled the timing cover off to check any visual problem. I did discover that there is no oil pressure at the tensioners. There is good pressure at the camshafts on both sides of motor. any input would be helpful, maybe a schematic of oil galleys. Is a 2003 s type type r 4.2
stanjag
Dec 29, 2024 08:26 PM
h4wk
Nov 27, 2015 05:10 PM
montypeek
Sep 6, 2015 04:57 PM
roumor
Aug 28, 2015 01:02 PM
brent65622
Aug 26, 2015 08:41 AM
