2002 S Type R 4.2 V8
Old Jun 20, 2014 | 05:09 AM
schumyn's Avatar
Default 2002 S Type R 4.2 V8
Where can I find specs for in-tank fuel pump pressure?
Old Jun 20, 2014 | 11:25 AM
xjrguy's Avatar
It's not easy to find in print, but the spec is:
3.8-5.0 Bar, [55-72 PSI] referenced to inlet manifold pressure.
It will hang right at 3.8 bar unless driving under a load.
Referenced to inlet pressure means taking into account inlet pressure, meaning manifold vacuum. In other words, manifold vacuum is also "sucking" the fuel from the injector.
To translate, if reading the rail pressure with a scantool, you'll see about 55 PSI. If reading with a mechanical gauge in the supply line, you'll see about 8-9 PSI less. That's the pull of the manifold vacuum.
And you thought it was simple!
Cheers,
Old Jun 20, 2014 | 11:30 AM
tbird6's Avatar
And it will change depending on RPM and load. I have watched my STR fuel pressure with a mechanical gauge for some time. I see a range around 45 psi to 70 psi give or take several psi. So don't expect a steady ready of 55 psi.
Old Jun 20, 2014 | 12:50 PM
xjrguy's Avatar
I worded that sort of poorly, didn't I?
Edited to clarify a bit.
Gotta keep me honest, guys........
Old Jun 20, 2014 | 04:48 PM
tbird6's Avatar
Hi Steve;
No you are correct, I just had to jump in!
I had a run with a bad fuel pressure sensor on my STR so I played around a good bit with my fuel pressure tester trying to troubleshoot it. At that time I had spikes as high as 110 psi!!
way2far
Aug 31, 2022 09:26 AM
Raul Lara
Sep 14, 2015 07:31 PM
KarimPA
Sep 3, 2015 07:32 PM
pnwrs2000
Sep 3, 2015 11:55 AM
dcvickers
Sep 2, 2015 06:14 PM
