2002 S-Type stuck rear door, unlocking problem
Old Jun 13, 2010 | 11:50 AM
VitoJaguar's Avatar
Default 2002 S-Type stuck rear door, unlocking problem
My son was holding the door handle on the outside as I unlocked the doors. Now the door will not open. The lock handle looks like it is sitting opened a bit. How do I get the door opened?
Old Jun 13, 2010 | 12:53 PM
You don't say what car you have.
Go round to the other side of the car open that door, then finish opening or closing the problem door from the inside.
Might be different depending on what car you have.
Old Jun 14, 2010 | 07:20 AM
VitoJaguar's Avatar
Default Door does not open
I have a 2002 s-Type. The rear passenger door does not open because the outside handle was being held while I unlocked the door from the inside, now the door lock seems jammed and will not open from the inside or the outside. It seems like the lever has been disingaged from the latch assembly. What can I do?
Old Jun 14, 2010 | 12:16 PM
Hi Vito, going to move this over to the S-Type section, hopefully the guys will be able to help you out, or in, as it were.
Old Jun 14, 2010 | 05:25 PM
I think you are going to have to pop the door card and see what has jammed up if all "jiggling" has failed.
stanjag
Dec 29, 2024 08:26 PM
montypeek
Sep 6, 2015 04:57 PM
blobthebuider
Sep 2, 2015 10:35 AM
roumor
Aug 28, 2015 01:02 PM
brent65622
Aug 26, 2015 08:41 AM
