2003 4.2 liter v8
Old Feb 4, 2016 | 09:46 PM
Norm St.Onge's Avatar
Default 2003 4.2 liter v8
i need a resourse for valve cover gaskets spark plug tube seals and bolt grommets. I understand that this is a Ford v8 if this is the case can i source these parts though ford. Ihave two cylanders that are leaking oil in the spark plugs and both coils are failing as a result any help would be appreciated.
Old Feb 5, 2016 | 03:03 AM
JagV8's Avatar
It's not a Ford V8. It's a Jaguar V8 hardly ever used by Ford even in its 4.0 form. But if you can get 'em from Ford for the 4.2 they may well be OK.
Old Feb 5, 2016 | 08:27 AM
pab's Avatar
pab
No, really, for anything on these cars you want to check with:
SNG Barratt - The Ultimate Jaguar Parts Specialist
first.
Jaguar: Grace, Pace, and Space - Sir William Lyons
Current Hers: '13 Lexus ES350
Current Mine: '08 Jaguar S-Type 4.2 "Satin Edition" (250.06 whp / 259.67 torque)
Past Ours: '05 X-Type 3.0/auto Jaguar Racing Green
Old Feb 5, 2016 | 08:53 AM
Mikey's Avatar
As already stated it's not a Ford engine at all. Try this: find the part numbers for the parts you want on a 1999-2002 S-type Jag 4.0L engine. Compare it to the part numbers on a 2003 S-type Jag 4.2L engine. If they're the same, go to a Lincoln dealer and ask for the parts for a Lincoln LS 3.9L engine.
Better yet, support one of the forum vendors.
Old Feb 19, 2016 | 07:28 PM
Catmobile's Avatar
Don't waste you time, get real Jaguar gaskets, etc. Shop around for better prices if you'd like.
Old Feb 21, 2016 | 12:56 PM
car5car's Avatar
Sure, get ripped off by Jag dealer!
vance580
Aug 31, 2021 08:30 AM
XJR2003
Feb 15, 2015 08:44 PM
scars
Dec 11, 2011 11:27 AM
carate
Oct 5, 2011 08:38 PM
willsmith11111
Jun 10, 2009 02:11 PM
