2003 jaguar s-type CD-Changer cables?
Old Apr 17, 2012 | 07:23 AM
Andrew74's Avatar
Question 2003 jaguar s-type CD-Changer cables?
This is my first time posting so I'll do my best including as many details as possible.
Maker: Jaguar
Model: s-type
Year: 2003
Other: v8
My car didn't come with a cd-changer equipped so I am looking to buy one so I can modify it for blue tooth capabilities. I am have a little trouble locating the cables for the unit. There are 4 unknown cables where the unit goes. One is the 3 prong power source, One has 10 pins (GRAY-Unknown), One has 15+ pins (Gray-Unknown), The last one doesn't have a connector because it was cut off ( IDK Why). The cut cable has 3 insulated wires running through it ( RED-Brown, Blue, Green ).
Here's a picture of a 2004 CD-Changer (Fits 2003 - 2008):
http://cas07.businessflow.ms/Current...e2476cd&size=2
Here's the picture of the 3 cables with connectors:
Here's The cut cable ( I think this is the cable that is connected to the one in the 1st picture ):
Is the cut cable the correct cable for the cd-changer?
What are the unknown cables for?
Is the cd-changer a plug & play situation or needs to be programmed?
Thanks in advanced.
Old Apr 17, 2012 | 08:10 AM
The audio system wiring can be found here https://docs.google.com/file/d/1mSzG...CPzc8rwF&pli=1
Hope that helps.
Old Apr 18, 2012 | 06:03 PM
ccc's Avatar
ccc
Assuming the 03 and 04 is the same, there should be a small 4 pin-ish amp connector and a two port optical fiber connection to the cd changer. The larger connectors may be for the nav unit and the amplifier that goes in the trunk on top of the changer.
neruda
Sep 3, 2015 07:45 PM
big d
Sep 3, 2015 07:37 PM
Aranon
Sep 1, 2015 01:00 PM
Terrance Williams
Aug 26, 2015 11:50 AM
NinoGrimace
Aug 26, 2015 05:15 AM
