2003 S-Type 4.2L V-8
Old Jan 17, 2016 | 09:49 PM
danielfv1939's Avatar
Default 2003 S-Type 4.2L V-8
Need to replace air conditioner compressor and both idler pulleys. Looking for suggestions on best way to do it myself.
Old Jan 18, 2016 | 07:25 AM
Jon89's Avatar
I recall several threads pertaining to this topic from four or five years ago. Search using "S-Type compressor replacement" as your key phrase and see what turns up....
Old Jan 18, 2016 | 10:45 AM
joycesjag's Avatar
The link below will help out. Its for the 3.0 but its basically the same as your V8. With the V8 you are going to find its much tighter, there is your PIA otherwise its a straight forward job. Be sure to read the link found in the "How To" on the proper recharge procedure.
https://www.jaguarforums.com/forum/s...ics-faq-55212/
Old Jan 18, 2016 | 04:37 PM
tbird6's Avatar
Be glad you don't have the STR! More braces on the front sub frame to fight.
I will give you one good suggestion. Remove both engine mount nuts and jack the engine up with a piece of wood on the oil pan. You will need the room.
You are in the same area so consider replacing the P/S pump if you find any leakage.
Lagonia
Feb 12, 2022 11:18 PM
danielhux
May 14, 2016 09:10 PM
XKJoe
Jan 25, 2016 04:49 AM
Nib
Jan 16, 2016 10:18 AM
jaguarguy13
XJ40 ( XJ81 )
Jan 14, 2016 11:03 PM
