2003 S type engine sound is louder
Old Apr 8, 2015 | 11:28 PM
kabs3012's Avatar
Default 2003 S type engine sound is louder
Hi,
I have a 03 jaguar s type with 112000 miles and since few weeks engine sound became louder on speeds more than 30mph and also time to time I notice engine oil sign is coming when I am in complete stop but when I start it goes away
A year ago had spark plugs and ignition coils changed
Any help is really appreciated
Old Apr 9, 2015 | 01:29 AM
JagV8's Avatar
If I understand you, you've VERY LOW oil pressure except at speed. Do not drive it till fixed.
Old Apr 9, 2015 | 02:45 AM
Nookieman's Avatar
+1
I would add that if the light is on you are very low in oil pressure all the time. The light usually goes out at just a few PSI. Anything much over idle and the motor needs more oil pressure than what it takes to put out that light to be happy. Check the oil level before starting the car again and add oil as needed...
Hopefully that fixes the noise you are hearing. If not, please let us know exactly what noise it makes with the correct amount of oil in it.
Again, do not start the car without checking the oil level with the dipstick and adding whatever amount of oil is needed to put the oil level between the "add" and "full" marks on the stick.
Old Apr 9, 2015 | 07:17 AM
joycesjag's Avatar
Sometimes the "OIL" cap is mislabeled, on some vehicles they numbered it rather than lettered it, look for "710".
For the whole story: https://www.jaguarforums.com/forum/o...s-store-61129/
Old Apr 9, 2015 | 07:44 AM
kabs3012's Avatar
Appreciate everyone's feedback
I did not check my engine oil level recently but will check now
With the same sound when I checked last time oil level was good and no issues
I have been driving it for sometime with the sound and did not realize the risk
Since one week I am noticing the engine oil sign on my dashboard so not sure
What's the cost of getting fixed this kind of problem
Old Apr 9, 2015 | 07:50 AM
kabs3012's Avatar
Since one week I am noticing there is no engine oil sign on my dashboard so not sure
Old Apr 9, 2015 | 08:00 AM
JagV8's Avatar
You need oil pressure or the engine will rapidly destroy itself.
Old Apr 9, 2015 | 10:07 AM
kabs3012's Avatar
Thanks for the info.. It's scary
Anyways what' the estimated cost to fix this issue and what causes the oil pressure issue for information purpose as I am new this world
Old Apr 9, 2015 | 10:32 AM
Mikey's Avatar
No one can possibly guess what it will cost to fix until the root cause of the problem is determined. There's dozens of things that might cause low oil pressure and 'noises'. It's possible that the two are not related.
I'm guessing you have little or no experience with working on cars. Now is not the time to learn. Please take the car to a trusted mechanic and give him as much information as possible.
Old Apr 9, 2015 | 03:18 PM
kabs3012's Avatar
I have found a guy on craiglist who claims to be jaguar specialist and not sure if it's good idea to go to him
I need advice on if this is a good idea. Should I try dealer or any other workshops
Reason for going to this craiglist guy is I am tired of dealer's work and want's to save money
Appreciate any ideas or thoughts around this
Old Apr 9, 2015 | 03:23 PM
joycesjag's Avatar
Do you have the ability to open the hood and check the oil? The dipstick is in plain view on drivers side.
Old Apr 9, 2015 | 03:40 PM
tbird6's Avatar
Thank you very much for a wonderful laugh!
710 indeed!
Similar to the letter to the editor of a local paper requesting the animal crossing sign be moved to less busy place because it would be safer for the animals to cross the road there!
You can guess who wrote that letter.
Old Apr 9, 2015 | 03:46 PM
kabs3012's Avatar
@joycesjag
Yes that kind of basic stuff I can do. I checked the oil level and it's fine
Old Apr 9, 2015 | 08:20 PM
kabs3012's Avatar
I got a feedback from dealer when I described my issue as below
Talking to my tech, first thing he said was to make sure that you have a Jaguar brand oil filter, after market filters don't also hold correct oil pressure. These vehicles typically don't have oil pressure issues, but we have replaced a number of sensors for this issue[/COLOR][/COLOR]
Any thoughts on this
Old Apr 11, 2015 | 11:55 AM
Jumpin' Jag Flash's Avatar
From: Pawleys Island, SC USA (formerly from Tabernacle, NJ USA)
Default USA Mid West - IL IN IA MI MN MO OH WI
Ask the members of the regional "USA Mid West - IL IN IA MI MN MO OH WI" sub-forum to recommend a reliable, trustworthy Jag mechanic in your area. It's probably a better idea than picking one off of Craigs List.
Here's the link to that regional forum, which covers your area of the USA - USA Mid West - IL IN IA MI MN MO OH WI
Old Apr 13, 2015 | 12:43 PM
kabs3012's Avatar
Update on what happened in last couple of days on my issue
1. Took it to dealer for a diagnose to ensure nothing was wrong with engine
Dealer quoted the problem to be as below
1. Front right Hub and bearing that's creating the sound while driving - Got it fixed
Dealer quoted - $700
Craig list mechanic fixed for 200 including part from Autozone
2. Dealer suggested the reason for oil leak is due to Oil pressure sending unit is gone bad and needs to be replaced that would cost $300 if done by dealer
When I inquired about the oil sending unit it's just for $15 on amazon and ebay......Need help to see if this is something we can do
3. My ride was bit rough idling..dealer said it's due to Fuel injectors gone bad and needs to be cleaned - It's done by dealer which cost me around $460
What I am looking here is getting some help on Oil pressure sending unit...Can I do myself or need to get it done by local mechanic or Jaguar dealer
Any advise is sincerely appreciated
Old Apr 13, 2015 | 04:04 PM
joycesjag's Avatar
Have you stated what engine you have?
You might want to go to "UserCP" upper left corner of any site page, click "Edit Signature" ad year and engine at the least, click "Save". This will help us help you every time you have an inquiry.
Old Apr 13, 2015 | 07:49 PM
kabs3012's Avatar
Default Hi Rick
I updated the information
It's a 2003 Jaguar S type 4.2 V8 w/spkg
Old Apr 13, 2015 | 07:54 PM
Mikey's Avatar
$460. Ouch. Did it help?
Old Apr 13, 2015 | 08:40 PM
kabs3012's Avatar
Default Hi Mikey
It helped in terms ride is smooth now but did not in $$$
I am trying to get the oil pressure switch fixed without going to dealer
