2003 S-type R "Humming??"
I'm looking to get into an 03 S-type R and the one I test drove was making a humming sound from the rear of the car, and the steering wheel was vibrating a bit. Also, the shift from first to second gear seemed squirmish, or "herky-jerky" - Anyone have any insight?
There's a known rear-end whine that shows up at certain speeds. There's a TSB on it that replaces the differential, I believe. Forum member "carelm" had this done last year under warranty to his 2005 S-Type 3.0. Out of warranty I'm sure it would have cost thousands. Try searching the forum using the phrase "rear end whine" and I'm sure you'll find his thread about this issue rather quickly....
Sounds like the car you're interested in also has a transmission issue and a steering or suspension issue. As "searanch" indicated above, I'd look for another car that doesn't exhibit these very costly problems....
If ya can't run then simply walk away...
With 82K that STR is no free ride. My advice is worth exactly what ya paid for it...
Over here in UK that price equates to about £5,500 which is cheap for an R of that age i.e. below the trade in value of a car with lesser mileage. You could be looking to potentially spend the same again or more should things be as bad as searanch says which brings it up to more than what you could buy one for from a franchised dealer complete with warranty back up.
It does look a good deal on the surface but it smells of quick sale to me.
Drive a few more so you have an idea of what the car should feel like and you need to find a mechanic who knows about these cars to look at it. The steering wheel vibration could be as simple as needing the tires balanced. I don't find these cars to shift very smoothly from 1st to 2nd especially under light acceleration. To me they seem to shift better in sport mode. In regular mode they shift too early causing some head bobbing. I wouldn't describe it as jerky but not as smooth as many other cars I've driven. The hum sounds like it could be the diff but I've never heard the problem personally. I also wonder what happens if you don't fix it? I wouldn't tolerate any noise in a $70k car, but for $8k I could live with a little hum (assuming nothing serious will happen).
3jagfamily
10-01-2015 01:49 AM
SoCalJagS
09-27-2015 09:20 AM
