2003 S type R rear subframe
Old Aug 13, 2021 | 03:38 PM
STRguy's Avatar
Default 2003 S type R rear subframe
Drifted my str in the rain and hit a curb, broke the rear passenger side suspension knuckle and wheel hub, which i've already got replaced at a shop after tracking down the part and a broken rim as well which i have also replaced already. The mechanic that did the knuckle and hub swap for me told me my subframe/ rear suspension crossmember (sorry i don't know the correct term for it) was bent and i needed to replace it. i cannot find one anywhere for my str i was wondering if a 2003 s type 3.0 would fit?
Old Aug 16, 2021 | 12:25 AM
xalty's Avatar
the bushings are different and stiffer but who cares, i think the sway bar is too but you can swap it
you need your 2.87 rear end
Old Aug 16, 2021 | 12:32 AM
STRguy's Avatar
Thank you i appreciate it everything on the car is fine except the rear subframe, that is what you were talking about correct?
Old Aug 16, 2021 | 12:33 AM
xalty's Avatar
yes
just make sure to change the diff with your current one
Old Aug 16, 2021 | 12:36 AM
STRguy's Avatar
yes
car is currently drivable and alliances pretty good, i just need to swap out the rear to be able to get the alignment perfect, but all of the rear is still original except for the hub and knuckle i just replaced, i'm going to go ahead and order the frame will let you know how it comes out
2003WHTSTR
Apr 8, 2021 01:12 PM
sanchez
XJ40 ( XJ81 )
17
May 22, 2018 09:01 PM
Anil4565
Nov 7, 2017 01:43 PM
mikewv100
Dec 31, 2013 03:54 PM
carlorner
Nov 2, 2011 06:16 PM
