Rear Stud Removal 2003 STR
Old Apr 7, 2021 | 01:05 PM
2003WHTSTR's Avatar
Default Rear Stud Removal 2003 STR
Does the hub/halfshaft need to be pulled away to remove the rear wheel studs?
Old Apr 7, 2021 | 01:11 PM
2003WHTSTR's Avatar
I forgot to mention it's a 2003 S-Type R. Found some stripped studs. Ordered Dorman 610-484 studs to replace.
Old Apr 7, 2021 | 01:29 PM
2003WHTSTR's Avatar
Got them out. Now the problem is getting the new ones in! On the few that were already replaced, someone had simply ground a flat spot into the head of the stud. I would prefer not to do this!
Old Apr 7, 2021 | 01:38 PM
scottjh9's Avatar
I ground a spot on the knuckle at about the 11 o clock position to slip them in one by one and pulled them in with an open end lug nut and impact them up tight
Old Apr 7, 2021 | 02:09 PM
2003WHTSTR's Avatar
Thanks! I'll see what I can. My car is Onyx White as well
Old Apr 7, 2021 | 02:50 PM
scottjh9's Avatar
knock a stud loose then turn the hub slowly and you will see the spot where it almost comes out. Grind the spot out. It looks like a a casting tab to use for holding the knuckle for machineing
Old Apr 7, 2021 | 06:20 PM
2003WHTSTR's Avatar
I was able to get a new stud in without doing any grinding. Unfortunately, tightening a nut to seat the stud resulted in stripping both the stud and the nut. It looks like I'll have to look into removing the shaft, so I can bang the studs in.
Old Apr 8, 2021 | 01:12 PM
2003WHTSTR's Avatar
I was able to get 5 good studs in. I ground a little of the stud head flat. They went straight in 12 o'clock. I froze the studs and heated the flange and used grease and an impact. They went in okay.
Thank you for your responses.
HushmoSTR 2003jag
Nov 15, 2014 01:37 AM
clubairth1
Nov 5, 2011 07:08 AM
carlorner
Nov 2, 2011 06:16 PM
godfatty420
Oct 26, 2011 09:16 AM
PhilT
Apr 6, 2011 07:50 AM
