2003 str horn not working....
Old Mar 2, 2008 | 12:40 PM
oblsk1's Avatar
Default 2003 str horn not working....
i checked the horn relay and fuse...any help as to what else the problem could be would be greatly appreciated.
Old Mar 2, 2008 | 12:56 PM
FactoryJaguarTech's Avatar
Default RE: 2003 str horn not working....
Maybe the horn itself. If you have a test light (DVOM is better) check for voltage at the horn while someone pushes the switch. If you have voltage at the horn then the horn is bad. If you do not get voltage there, then probably the horn push switch behind airbag is bad.
Remeber the ignition should be on while you check the voltage at horn. Just unplug it and probe connector gently. Let us know what you find.
Old Mar 2, 2008 | 01:07 PM
oblsk1's Avatar
thanks...but...next question...how do i access the horn???
Old Mar 2, 2008 | 01:14 PM
Open the hood and look down behind grill bolted to frame.
You may have to take off that upper cover with the 4 screw clips holding it in place.
Old Mar 2, 2008 | 03:23 PM
oblsk1's Avatar
there is a piece behind the grill blocking access ...it looks like the whole bumper has to come off...: (
Old Mar 2, 2008 | 09:01 PM
What? You should be able to access it fine. Take a picture of what you are looking at and post it. You should be able to get to connector easily.
Old Mar 3, 2008 | 05:39 PM
oblsk1's Avatar
this is what i see when i look down behind the grill
[IMG]local://upfiles/3234/A942AB16B1C24FD9A642BBC88A10BB4F.jpg[/IMG]
Old Mar 3, 2008 | 05:41 PM
Was that a joke.....as in you see nothing? Cause thats what I see in your post.....lol
Did you remove the radiator cover? Then look down there?
Old Mar 3, 2008 | 05:45 PM
Sorry....now I understand. Can you not move that cover out the way? It looks like a couple of fir tree push pins. The horn is right below that thing.
Old Mar 3, 2008 | 05:48 PM
The grill should come out without removing entire bumper. That may give you the access you need.
There is only 4 bolts holding it in and the bumper definitly does not need to come off for that. All you want is access to the connector for testing.
Old Mar 3, 2008 | 05:50 PM
oblsk1's Avatar
there is a piece behind the grill that is blocking access to go to where the horn is ....when you take off the radiator shield it's still in the way
Old Mar 3, 2008 | 05:54 PM
Sorry we posted at same time. Read the above. Remove the grill. Only 4 bolts hold it in. 2 at top and two behind it. All you need is access to connector so you can see if voltage there. If there is, horn itself is bad. I apologise, sometimes I am not good at explaining how to get to things.
Old Mar 3, 2008 | 06:07 PM
oblsk1's Avatar
ok...i'll try it in the morning....thanks
Old Mar 4, 2008 | 09:03 AM
oblsk1's Avatar
still blocked with the grill off....finally got access by moving the lower mesh and just testing connection...no voltage there
Old Mar 4, 2008 | 07:06 PM
Then if you are positive the relay and fuse are good, I would suspect horn contacts. You need to disconnect battery, then turn steering wheel 90 degrees from center each way. There is a 30 torx screw on each side holding airbag in. Loosen them up - they wont come out - and pull airbag forward. See if the thrid connector (not the two on airbag) is plugged in. If so, I would say horn contacts bad. You can replace them yourself.
WAIT FOR 5 MINUTES MINIMUM AFTER BATTERY DISCONNECT BEFORE REMOVING AIRBAG
Old Mar 9, 2008 | 12:54 AM
oblsk1's Avatar
can't find a replacement horn switch....is that a dealer only part???
Old Mar 9, 2008 | 02:09 PM
Yes dealer only. But when you checked for voltage at horn, did you have ignition on and someone push horn switch?
Just checking before we go overboard here.
Old Mar 10, 2008 | 11:28 PM
oblsk1's Avatar
yes ignition was on and person was pushing horn in
Old Mar 10, 2008 | 11:30 PM
oblsk1's Avatar
are the horn contacts different from the horn switch...
Old Mar 11, 2008 | 07:40 PM
It is the horn push switch behind airbag. Dealer will now what you are asking for. Does your airbag light come on by the way? The contacts run through the cassette reel also.
