2004 S Type R coolant change
Old Aug 9, 2010 | 10:10 AM
FJG123's Avatar
Default 2004 S Type R coolant change
Hello
I have a 2004 S Type R that I am tryign to change the coolant on.The coolant is now 5 years old.Can someone tell me the procedure on changing it?I was going to change to Evans Waterless Propylene Glycol coolant.
I also wanted to change the Differential fluid and was going to use Royal Puple 75 W 140 synthetic gear oil.Will this work as the dealership does not recomend anything except jag gear oil.
Thanks Fitz
Old Aug 9, 2010 | 10:38 AM
JagV8's Avatar
Workshop manual $10 ebay
Use only the jag coolant unless you're brave.
Look up the diff oil spec but no-one seems to change it LOL
Old Aug 9, 2010 | 07:19 PM
jag79's Avatar
Well Jag coolant is all very good, but you can use I gallon of the jag coolant and the rest top it off with PRestone 50/50 which blends in with all colors even the Jag's Orange coolant, this was told to me by a Jag tech
Old Aug 10, 2010 | 01:35 AM
JagV8's Avatar
jag's is affordable enough especially as you change it only every 5 years. You should not need to top it up as it's a sealed system.
Old Aug 10, 2010 | 12:14 PM
tbird6's Avatar
Your car uses Dex-cool. Much cheaper to just stay with the factory fill. I have changed the rear end fluid and it was black and nasty!! Please find the Jaguar spec. I have posted it on the forum before. I was able to match the Jaguar rear end lube spec at NAPA with a full synthetic fluid. I used a hand pump to suck the fluid out of the rear end so I did not have to remove the rear cover and change the gasket.
Here is my rear end fluid change post. Should answer all your questions.
http://tinyurl.com/242qfub
Old Aug 15, 2010 | 11:19 PM
FJG123's Avatar
Thanks for the help guys.Are the tech guides on ebay the same for the S type R?
Thansk Fitz
Old Aug 16, 2010 | 01:56 AM
JagV8's Avatar
Yes.
stanjag
Dec 29, 2024 08:26 PM
johanasu
Sep 3, 2015 12:39 PM
WhiteTardis
Sep 2, 2015 10:32 AM
EastFalk
Aug 29, 2015 08:22 PM
Aegis21
Aug 27, 2015 08:30 AM
