2005 S type Battery keeps draining
Old Jan 22, 2015 | 03:46 AM
Aishaq20's Avatar
Question 2005 S type Battery keeps draining
I recently replaced the battery on my 2005 S Type, after it wouldn't start. I put in a new a battery and it worked great for a good 2 weeks, and now the Battery is dead again. I suspect it's draining from somewhere but don't know where to start to looking. I checked the alternator and it's charging just fine. Has anyone had any similar issues?
Old Jan 22, 2015 | 04:43 AM
Firstly you are NEW, so welcome.
There are "hundreds" of threads on this in the "search" function area. Type in "battery drain" as a starter.
I had this issue with the Silver S. However it is an X200, and yours is an X204, and the electrickery is waaaaay different.
Old Jan 23, 2015 | 03:42 PM
Cobbler's Avatar
Make sure the battery ground wire has a good connection to ground. Follow the wire off the battery and see where it is fastened and be sure the connection is solid.
Old Jan 24, 2015 | 07:45 PM
Jumpin' Jag Flash's Avatar
From: Pawleys Island, SC USA (formerly from Tabernacle, NJ USA)
I'd recommend you thoroughly search the S-Type forum for battery drain issues. Seems they are all related to a short / pinched wire somewhere, or aftermarket alternator that seems compatible but isn't.
I think TBird, JagV8 and Mikey are all knowledgeable about battery drain issues, but do search the forum first. There is at least one other thread running concurrently with same issue as yours. Search is your best friend on the Jag Forums.
Old Jan 24, 2015 | 08:24 PM
Default Stuck Ignition Key Flap
Here's one of the best threads on Battery Drain -
Excessive current draw
Old May 12, 2024 | 01:25 PM
Yaron Stype's Avatar
It's a shame that Jaguar didn't provide the Climate control Module with basic protections for all ports related to operating modules at the vehicle.
Most of the electrical problems start in this module
The way to deal with the problem of electricity leakage:
Disconnect the + voltage from the battery
Connect an ammeter between the battery and the + connector
It is important to close doors and take out the key, that the trunk is open, there is a lamp that will add electricity flow.
Start disconnecting relays in the trunk and engine.
See which relay reduces current consumption up to 300 milliamps
If you did not find the connection between the relays and the power consumption, go to disconnect modules:
In the trunk:
ELECTRONIC PARKING
BRAKE MODULE
REAR ELECTRONIC MODULE
TRAILER TOWING MODULE
ADAPTIVE DAMPING
CONTROL MODULE
PARKING AID
FRONT ELECTRONIC MODULE
Successfully ....
I added a 100A relay with a remote on the top of the battery,
You can order Aliexpress >> Battery Relay Switch 12V Remote Control Battery Disconnect Cut Off Switch Anti-Theft Battery Isolator for Car Camping Trailer
Old May 12, 2024 | 03:27 PM
Beretta9's Avatar
I also use one of these on one of my jaguars. It sits for weeks sometimes so this relay is cheap and works amazing.
Old Jun 6, 2024 | 09:42 AM
VR6Rado's Avatar
In the trunk:
ELECTRONIC PARKING
BRAKE MODULE
ADAPTIVE DAMPING
CONTROL MODULE
PARKING AID
Successfully ....
I didn't even think that anyone made a remote control relay, that's genius! I wonder if you could modify that to wire into an individual circuit to only cut power to the offending module so you don't lose learned values in all the other modules.
Old Jun 7, 2024 | 03:24 AM
cat_as_trophy's Avatar
Suggest you go to the Stickies at top of this forum . . . .S-Type 'HOW TO' Guides > Miscellaneous > Quiescent Current Drain
https://www.jaguarforums.com/forum/s...-drain-123535/
Read the PDF attached to Post #1, then read posts 3 and 4. This Sticky may be a decade old, but the S-Types, this issue, and the solutions are still valid and worth repeating.
Best wishes,
Old Jun 7, 2024 | 03:52 AM
M-e-l-l-o-w's Avatar
A simple visual check to for a known common problem is make sure that dust cover is going back across the ingnition barrel hole when the key is taken out.
If this tiny cover over the hole is stuck in the open position the car will not fully shut down after 40 mins.
This will drain the battery.
It may not be that, but is a simple one to check.
Mellow
Old Jun 7, 2024 | 05:59 PM
Beretta9's Avatar
I think it’s possible. These relays are pretty cool imo and really cheap.
stanjag
Dec 29, 2024 08:26 PM
TXJagR
Mar 12, 2016 11:12 AM
Thia
Sep 1, 2015 10:36 AM
DeaconHull
Aug 28, 2015 05:26 PM
divingmom
Aug 25, 2015 07:54 PM
