2005 s type R
Old May 19, 2014 | 09:44 AM
yeffots's Avatar
Default 2005 s type R
I have had my s type for 4 years now. Just this past week I have encountered a strange problem. When I return the to vehicle after being shut off for a minimum if 30 minutes, the interior blower fan is blowing at high speed. when I turn the key to the first position or all the way on it turns off. I read on a post from 2009 this may be a "feature" not a problem. My only true concern is whether this will drain my battery. Can anyone help? Thanks
Old May 19, 2014 | 12:15 PM
tbird6's Avatar
I have a 2005 STR and have never seen it but you are correct that it has been posted before and does appear to be normal.
The only thing I would say is:
Do you have any other electrical things that are different from what you think they should be?
How old is the battery?
So I would watch it to see if it's a problem. Not sure I buy the explanation of why it's running but it's pretty rare so we don't have much to go on?
Old May 19, 2014 | 12:34 PM
yeffots's Avatar
Thanks for the response. The battery is about 2 years old. I guess no matter what the cause is it surely is using/draining the battery. That's my biggest concern so right now I disconnect and connect that battery whenever I will be away from the car more than 30 minutes. Such an inconvenience but a dead battery is a bigger one.
Old May 19, 2014 | 06:09 PM
Bad Cattitude's Avatar
Check the fluid level in the battery first. It may not be too far gone.
way2far
Aug 31, 2022 09:26 AM
ZJag
26
Sep 5, 2016 03:33 PM
raffoulig
Sep 8, 2015 01:56 AM
KarimPA
Sep 3, 2015 07:32 PM
laserguy
Sep 3, 2015 02:02 PM
