2005 S Type wont shift into gear
Old Sep 17, 2009 | 07:47 PM
JOsworth's Avatar
Search the forums for shift linkage.
Others have had issues where a plastic part has broken in the linkage. I haven't had the problem myself but your issue sounds like it may be it.
Old Sep 18, 2009 | 10:40 AM
ken@britishparts.com's Avatar
Very common for the white plastic piece to break inside the shifter. I have an aluminum replacement for $175. It won't break again!
Old Sep 19, 2009 | 12:02 AM
poboyblues's Avatar
On the later S types, the two 8mm headed bolts that hold the trans cable to the side of the transmission work loose and at times completely fall out. Give those bolts a look before replacing anything. The later S types also had a different shifter than the earlier S, and are much more robust.
Old Sep 21, 2009 | 06:06 AM
JOsworth's Avatar
I'm not the Original Poster but thanks Poboy for that tip. I'll add that to the list of service items to check! Great tip!
Sprayall
May 30, 2021 08:13 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
Sprayall
Sep 3, 2015 07:49 PM
dcvickers
Sep 2, 2015 06:14 PM
XFR_Gold
Sep 2, 2015 12:24 PM
