4.2 l V8R coolant leak
Old Jul 18, 2020 | 05:43 AM
Jean-Michel's Avatar
Default 4.2 l V8R coolant leak
Hello,
Who could tell me about a problem with a major leak of engine coolant not running? Fluid is flowing backwards on each side of the gearbox and is not visible from above or below the engine. The car is 18 years old but only 80,000 kms. Thank you for your answers, explanatory photos welcome.
Regards,
Jean Michel
Old Jul 18, 2020 | 07:04 AM
JagV8's Avatar
Any time I can't see something I use a USB snake-like camera (borescope) - cost about 10euro - but sometimes I expect a smartphone would work.
Old Jul 18, 2020 | 09:16 AM
Thank you, the search was done with the endoscope but it did not find the origin of the leak. that's why I launched this call for "help", because as a last resort the mechanic suggests that I take out the engine.
Old Jul 18, 2020 | 10:32 AM
NBCat's Avatar
Leak is most likely from one of the hoses under the inlet manifold, or supercharger in the case of the R variant. Check with a cooling system pressure tester after the vehicle is cold. Pump the system to 1 bar and search for leaks.
Old Jul 18, 2020 | 03:43 PM
scottjh9's Avatar
There is no way to tell which hose gave without pulling the supercharger or intake, whichever the case may be....i am in the middle of such repair right now....both hoses will be replaced....once in a great while the 90 degree hose attached to the water rail will split and run down the valley and off the back of the engine
Old Jul 18, 2020 | 04:31 PM
Default Coolant leak
Thanks for that info, I think the easiest way is to take the intake apart to see what's going on below.
Old Jul 18, 2020 | 04:36 PM
Thanks for that info, I think the easiest way is to take the intake apart to see what's going on below. Especially since I have supplied almost all the hoses with a view to replacing them as a precaution.
Old Jul 18, 2020 | 04:40 PM
Old Jul 18, 2020 | 05:15 PM
scottjh9's Avatar
good idea...order the 2 hoses under the intake and the 90 degree outlet hose i mentioned...the coolant hose to throttle body is found in the throttle body parts diagram...the coolant hose to egr is found in the egr diagram and the 90 big hose is found in engine cooling/water rail diagram....I use jaguarlandroverclassicparts.com for their diagrams or terrysjag
Old Jul 18, 2020 | 05:19 PM
NBCat's Avatar
@Jean-Michel, since you're in France, you can also source parts from SNG Barratt France:
https://www.sngbarratt.com/Francais/...guage=Francais
Old Jul 18, 2020 | 07:04 PM
scottjh9's Avatar
thanks NBCat...on my phone it does not give location....he should be good to go then
NBCat
Old Jul 19, 2020 | 07:32 AM
Thank you, I have already ordered all the hoses from them, but it is the identification of the leak that poses a problem for me.
Best regards,
Old Jul 20, 2020 | 05:11 PM
Default Coolant leak continuation and end
Ultimately after dismantling the admission and everything that goes with it, the culprit has been found (I will try to attach the photo). Apparently, this hose suffers a lot from the heat inside the V8. in addition to its replacement, it is planned to thermally insulate it to protect it. The parts were ordered from SNG Barratt
Have a lovely day everybody
Jean Michel
Old Jul 20, 2020 | 06:26 PM
scottjh9's Avatar
Take a good look at all the vacuum connectors also...if in doubt, replace it....make sure to use a new throttle body to induction elbow gasket if the black sealant is chipping away....
Old Jul 20, 2020 | 07:06 PM
NBCat's Avatar
+1 on scottjh9's recommendations above.
If the vehicle is normally aspirated, it's also a good idea to replace the water outlet and thermostat assembly since the inlet manifold is out of the way allowing access to the Torx screws. The JLR part number is AJ811793.
Old Jul 21, 2020 | 01:39 AM
Default Thanks
Thank you for your valuable advice, as a reminder this is a 4.2 l V8R from November 2002. Do not worry all the surrounding parts are checked and replaced. The car benefited from a major overhaul with all fluids being changed, as well as the replacement of all the rear axle tie rods. The maintenance carried out is carried out with a collector's spirit, since it is parked in the garage with a Citroën Traction 11B from 1949, a Citroën DSuper 5 from 1973, a Citroën 2 CV6 from 1980 and a Motoguzzi California Titanium from 2003.
Best regards.
Jean Michel
David Dulson
Jun 4, 2020 01:51 PM
atlcontracting14
May 10, 2020 03:13 PM
Drak
Dec 11, 2015 03:45 PM
Sonspit
Feb 19, 2015 10:26 AM
jmcGoBlue
Mar 5, 2012 11:41 AM
