4.2 S Type R chain tensioner
Old Jan 30, 2017 | 04:46 AM
melhookv12's Avatar
Default 4.2 S Type R chain tensioner
Early 4.2. Were the later tensioners fitted ? Or do they need checking ?
Old Jan 30, 2017 | 05:20 AM
JagV8's Avatar
How early? Engine date?
Almost all, perhaps all, use the later kind - but if you have a pre-production car....
Old Jan 31, 2017 | 03:56 AM
melhookv12's Avatar
Not sure of engine number. It's a 2002 registered. It's got a noise on start up. Haven't looked at it yet. Will try to getc the engine number.
is the engine number a definitive answer?
thanks for reply
Old Jan 31, 2017 | 04:50 AM
JagV8's Avatar
Well really it's the date on the engine, which can be a long time before reg date (e.g. my car was built months before, and engine earlier still).
If the VIN is well after M45255 you've a fair chance.
Old Feb 2, 2017 | 10:45 AM
clubairth1's Avatar
Community Influencer
All 4.2L NA and SC come from the factory with the latest tensioner's.
It's very rare to have any tensioner problems with these later V-8's.
Are you sure that is the noise?
I would remove some belts and start the engine because you will spend a ton of money changing them.
Old Feb 3, 2017 | 11:24 AM
melhookv12's Avatar
Vin was m53...
knick on start up. Big end or main bearing goes with oil pressure. Not good
