5r55n auto gearbox swap
Old Dec 3, 2019 | 11:29 AM
mcteg's Avatar
Default 5r55n auto gearbox swap
I have found a replacement 5r55n autobox to fit to my 2000 stype .
when fitted the ecu is coming up with lots and lots of faults.
Two people independantly told me the box was good.
Is there some electrical ecu handshake needed to make the gearbox work.
Old Dec 3, 2019 | 11:38 AM
NBCat's Avatar
Check fluid level and electrical connections first.
Did anyone remove the pan and solenoid pack?
Old Dec 3, 2019 | 11:41 AM
NBCat's Avatar
Here is a link to the Workshop Manual for the 5R55N:
https://www.dropbox.com/s/gez4sqw92v...arbox.pdf?dl=0
What was wrong with the gearbox originally fitted to the vehicle?
Old Dec 3, 2019 | 11:56 AM
mcteg's Avatar
Hi guys
The original 5r55n gearbox was oil changed and new filter fitted. It started slipping and produced the incorrect gear ratio fault codes when a sophisticated OBD scanner was put on.
i considered it cheaper to swap the auto box than pay for a servo valve repair.
The replacement autobox came with two independent approvals. The vendor who sold the car to a person who wanted the engine, and the person who wanted the engine and had driven the car to his workshop.
The replacement autobox received an oil and filter change before fitting.
I just don't believe all the fault codes now coming up. The car has almost no drive now . Reverse being the best. if you run through the gearbox P N R D you can feel it selecting.
charles
Old Dec 3, 2019 | 12:02 PM
NBCat's Avatar
The most common failure of the 5R55N is the intermediate and or overdrive band due to servo bore wear.
Has anyone checked the fluid level and electrical connector after fitting the used gearbox?
Old Dec 3, 2019 | 12:36 PM
mcteg's Avatar
Thank you for your replies.
I did the job myself and hope that when I revisit my work I will find a silly mistake.
Update will follow .
mcteg
mcteg
Apr 1, 2021 09:42 AM
Chris Steineger
XK120 XK140 XK150
Jun 29, 2018 04:10 PM
Mac Mughal
Nov 23, 2017 05:40 PM
CyberJag
19
Jun 18, 2016 04:14 AM
stately
May 23, 2010 04:23 PM
