ABS Fault
My battery seems OK I have a voltmeter mounted in the trunk so I can keep an eye on it regularly. I also put it on charge with a smart charger (Ctek 5.0)
I have checked all the fuses that I can find related to the ABS. The outputs from the wheels sensors all read the same when checked live with the diagnostic tool.
Right now I am in the process of pulling off the front bumper as there is a wire loom that runs across that can chafe (so I'm told) so will examine that.
I have taken a quick look at the plug into the ABS pump, that seems it would be right job to get to that. Will leave that on the back burner for now
Regards........................................... ..................IP
You may find this thread of interest:
https://www.jaguarforums.com/forum/s...attery-193787/
Roughly half the time, based on the collective forum experience, the battery itself is the problem. In almost all of those cases, the starter cranking speed was normal, so don't base the battery condition on that alone.
jagxtypeboy
01-20-2008 10:56 AM
frombenz2jag
01-17-2008 06:45 PM
frombenz2jag
01-16-2008 05:38 PM
