ABS Fault
Old Jun 21, 2018 | 03:14 AM
Irish Pappy's Avatar
Default ABS Fault
I have the ABS fault showing on my dash. A scan with a diagnostic tool (iCarsoft 930) shows code C0082 This is not very helpful. What would be the next step?
2006 S type 3.0
Thanks...................Tony
Old Jun 21, 2018 | 10:49 AM
robdos's Avatar
Check the battery. Mines was low and the car showed the ABS light - it was 13 years old - so a new one fixed the problem.
Old Jun 21, 2018 | 11:34 AM
Thanks for that robdos,
My battery seems OK I have a voltmeter mounted in the trunk so I can keep an eye on it regularly. I also put it on charge with a smart charger (Ctek 5.0)
I have checked all the fuses that I can find related to the ABS. The outputs from the wheels sensors all read the same when checked live with the diagnostic tool.
Right now I am in the process of pulling off the front bumper as there is a wire loom that runs across that can chafe (so I'm told) so will examine that.
I have taken a quick look at the plug into the ABS pump, that seems it would be right job to get to that. Will leave that on the back burner for now
Regards........................................... ..................IP
Old Jun 21, 2018 | 11:17 PM
kr98664's Avatar
Originally Posted by Irish Pappy
My battery seems OK...
You may find this thread of interest:
https://www.jaguarforums.com/forum/s...attery-193787/
Roughly half the time, based on the collective forum experience, the battery itself is the problem. In almost all of those cases, the starter cranking speed was normal, so don't base the battery condition on that alone.
charlie.p
Nov 3, 2023 09:20 PM
Don B
General Tech Help
Nov 9, 2015 12:59 PM
jagxtypeboy
Jan 20, 2008 10:56 AM
frombenz2jag
Jan 17, 2008 06:45 PM
frombenz2jag
Jan 16, 2008 05:38 PM
