Abs fault
Old Oct 1, 2010 | 09:25 AM
kheestand's Avatar
Default Abs fault
2003 S-type V8
I Replaced both Wheel Bearing/Hub Assembly in the front new brakes and rotors now I am getting Abs Fault No Disk Available And the front drivers brake sounds like it rubbing but I have taking them apart 3-4 times everything looks fine..
Old Oct 1, 2010 | 10:12 AM
JagV8's Avatar
That'll be No DSC lol
Did you check the new and old parts are identical in size everywhere (apart from wear)? There are so many variants that you could easily have one or more that aren't right
Old Oct 1, 2010 | 10:47 AM
kheestand's Avatar
yes it no dsc
Old Oct 1, 2010 | 11:18 AM
carfix's Avatar
Is there any chance that you turned the ignition on when the ABS sensor leads were disconnected?
I foolishly did this and a fault code was registered. It did not clear once I reconnected the lead and I had to get Jaguar to clear the fault code using their diagnostic machine.
Old Oct 1, 2010 | 11:27 AM
kheestand's Avatar
My youngest was in the car and she might have
goges
Oct 5, 2015 04:53 PM
millertic
Sep 30, 2015 08:11 PM
leep123
Sep 30, 2015 03:41 PM
mrplow58
Sep 30, 2015 08:56 AM
