ABS light
Old Dec 29, 2021 | 09:08 AM
rethorets's Avatar
Default ABS light
So I replaced the unit bearings on my 01 S Type and now the ABS light along with the E Brake light and the traction control light are on.
I'm pretty sure I have everything plugged in properly.
Is there a reset procedure?
Old Jan 2, 2022 | 06:08 PM
elDariusVargas's Avatar
Sounds like the sensor or its harness might have been damaged during the procedure.
do you have the workshop manual?
there are some pinpoint tests you can do to see if the circuits are ok.
if you manage to isolate the problem to the sensor, its worth taking a look at the harness since its happed right after working in the area
Old Jan 5, 2022 | 05:45 AM
M-e-l-l-o-w's Avatar
I agree that it does sound like a wheel sensor fault or the wires to it.Have a good look in the connector for any damage.
However, the wheels sensors are known to fail with normal use. I have had two fail in the last 5 years.
The jaguar SDD (for 05MY or newer cars) or IDS (for pre 05 facelift cars) software will tell you what sensor is faulty as it may not be the one you have worked on, but it probably is!!
Mellow
dbunt101
Dec 19, 2021 07:36 AM
fresno
May 11, 2016 12:34 PM
cygnus x1
Jun 14, 2015 12:07 PM
kstevusa
Jan 28, 2015 04:39 AM
Spurlee
Jul 14, 2009 02:46 PM
