ac/ problem hot air only
i have 2000 s type with 4.0
it only blows hot air the ccv has been replaced after find that the old one showed sand like debris in tubes when the system was refilled and charged air was coming out cooler(not cold ) but cooler than before after charging then switch over to heater and now only hot air is blowing again any help would be useful
ump!
ump!
Welcome to the forum ump!,
I've moved your question from General Tech Help to S-Type forum. Members here with the same model will be able to help.
Im no mechanic but ill tell you what happened to mine. My air conditioning started to blow hot air, then cold air, etc. Before I had a chance to take it to a mechanic it was stuck on hot air no matter what temp, mode i put it in. Took it to a mechanic and the guy was able to diagnose it pretty well. Turns out i had a small radiator leak and the radiator fluid was dripping on an air conditioning component ( if im not mistaken its called a DCCV) and this cause a short to burn out my climate control module. After having the radiator leak fixed (rubber hose and DCCV replaced) I pulled out the control module and sure enough it had obvious burn marks. Took it to a local Computer repair place and they cleaned up the burned bridges, redrew them and I was back in business. Check your coolant level, if your loosing any, even a small amount, that might be the cause. Here are a few links related to this issue.
https://www.jaguarforums.com/forum/s...acement-70079/
https://www.jaguarforums.com/forum/s...003-faq-36719/
Probesport
Jun 23, 2017 03:20 PM
mikechinea
Apr 16, 2017 05:27 PM
Michael Wittmann
Mar 27, 2016 07:45 PM
