Advice please Auto gear select strange
Old Mar 24, 2010 | 05:59 PM
adam01's Avatar
Question Advice please Auto gear select strange
hi all
Strange thing this issue i have
when i put gear stick in drive nothing happens , but when i move gear stick around the U as in move to 2nd and than back to drive it works as normal , cant understand this she drives as sweep as a nut all advice would be appreciated
Adam
1999 s type 3.0 auto petrol
Old Mar 24, 2010 | 06:23 PM
adam01's Avatar
its ok now i found the info
It is the shift cable. It just needs adjusted. You need a 15/16 wrench and vice grips. Fung fu grip the center console off the car. Put it in neutral. Then put the vice grips just behind the nut, on the metal. Back off one of the nuts a little, then tighten the other side. It will move the cable inside. Then put it from neutral to reverse and back to neutral and back to drive. The distance between R-N and N-D should be the same. The letters should light up at same distance I mean. If it isnt, go the other direction. If you are not comfortable doing that, have someone else do it. But it is just an adjustment.
tomsjag
Jun 10, 2023 10:02 AM
trosty
26
Dec 18, 2022 06:40 PM
simo5555
Sep 9, 2015 06:22 AM
Doovoe
Sep 8, 2015 05:42 PM
carelm
Sep 5, 2015 01:13 AM
