All Of A Sudden - ABS Fault and CEL
Old Feb 24, 2014 | 10:43 PM
55jag05's Avatar
Default All Of A Sudden - ABS Fault and CEL
I put my scanner on it and got P1111 and C1165
Also noticed the gas cap was loose and tightened it.
C1165 seems to be a rear ABS sensor so I'll check that.
I erased the P1111 and the CEL went off............for a while.
Now it's back on.
Do I need a special scanner to read the codes on a Jag?
Old Feb 25, 2014 | 02:15 AM
JagV8's Avatar
Erasing P1111 rather suggests you didn't look it up (Search or get codes PDF or get JTIS - all are free here).
You don't need a special OBD tool for standard OBD stuff but there again not every tool is built properly. There's a detailed thread in General Tech of ones people have tried and reported about.
Old Feb 25, 2014 | 09:08 AM
55jag05's Avatar
Well, now I have a P1000 code which I know means the diagnostic check is not complete. But, the CEL is on and there's no code for that.
Old Feb 25, 2014 | 09:56 AM
JagV8's Avatar
CEL (properly, MIL) and no code. Don't think that even meets the law (*)! Something's very odd. Suspect your OBD tool.
(*) yours or mine
Old Feb 25, 2014 | 11:32 AM
aholbro1's Avatar
If you read a C1165 you've already got the special tool. If you haven't fixed that, I suspect that is what is illuminating your MiL
By "went off for a while" do you mean for about 100 yds of driving or until you hit 5 or 10 mph? I think the ABS system does a BIT check after every start-up and if a malfunction is present, you don't get an indication until you pass the neighbor's house two doors down (in my case, anyway, your mileage may vary)
Old Feb 25, 2014 | 11:45 AM
55jag05's Avatar
During a 10 mile ride yesterday, the CEL and ABS Fault went off. Then I went over some railroad tracks and the ABS came back on.
After stopping for a while the CEL came back on when I restarted.
The car runs fine and the brakes feel fine.
Old Mar 5, 2014 | 05:51 PM
Rimmer's Avatar
Check the wiring on the wheel hub. I had to replace my front passenger hub and got a cheap one off ebay. About six months later the plastic cover that has the sensor just fell loose. I haven't changed it back out yet but have pressed it back in place. When it falls loose I get the ABS light and of course my Traction Control gets turned off.
This may be way off but you mentioned a code about the rear ABS sensor. Might help to look.
bdboyle
Sep 16, 2019 05:58 PM
RSpi
Mar 21, 2016 12:02 PM
emilime75
XJ XJ12 ( X305 )
Oct 19, 2015 09:55 PM
Dave1109971
Sep 30, 2015 11:04 PM
leep123
Sep 30, 2015 03:41 PM
