Amplifier?
Old Oct 21, 2008 | 09:08 PM
CleanKat's Avatar
Default Amplifier?
I have a 2004 S-type with stock Navi/stereo, I'm looking to add an amp, but I'm having a problem finding a wire to hook the aux on off the wire for the amp. Can anyone tell me how they hooked thier amps to the stock system? I got power but need a signal...thanks
Also what color wires for the door speakers?
Old Oct 22, 2008 | 09:04 AM
christo's Avatar
Default RE: Amplifier?
You have to buy a low level to rca converter. Unless your amp can accept the low level inputs. In that case you would just wire your rear speaker wires to the appropriate wires on your amp. I am not sure about the wire colors but if you call any stereo shop and ask nicely they will usually tell you - I have done it before. What kind of amp and sub are you putting in?
Old Oct 23, 2008 | 02:34 PM
CleanKat's Avatar
Low level to rca converter is for the subs/bass right? I have an Infinity Reference 7540A that I would to power my Infinity Kappa 682.9cf.
Old Oct 23, 2008 | 02:38 PM
christo's Avatar
It can run anything you plug it into. Its the best option to use the stock radio. I actually have 2 amps running off the converter right now.
Old Oct 23, 2008 | 03:20 PM
CleanKat's Avatar
Im using a line coverter & Im not getting a signal, how/waht are you usinfg to get a signal?
Old Oct 23, 2008 | 03:29 PM
christo's Avatar
There should be some wires hanging off the back or it. They need to be matched up with your rear speaker wires - make sure positive and negative are connected properly. The instruction booklet that came with it should have and example. Also, there will be 2 other wires that may need to be connected to a power source if you still do not get a signal.
Just to ask, the amps are turning on, the remote wire has juice and you have a good ground - correct?
Old Oct 23, 2008 | 04:01 PM
CleanKat's Avatar
Better yet can you tell me what did you use for the aux signal ...what wire & where? I dont know about your X-type but the S-type has a digital sinal & that is what Im trying to get around to get a signal...
Old Oct 23, 2008 | 04:21 PM
CleanKat's Avatar
ORIGINAL: christo
Yup got juice but no signal?
Old Oct 23, 2008 | 05:43 PM
christo's Avatar
But the speaker wires should be copper no? Have you identified the wires correctly? Where are you tapping them from? Not sure I know what you mean about the aux signal - are you trying to run another type of media via aux connection?
Old Oct 23, 2008 | 07:12 PM
CleanKat's Avatar
I have a good ground and positive...I just need the auxilary singnal to make it turn on and off. Im using the signal from the oem amp but it is digital. What did you use?
Old Oct 23, 2008 | 08:10 PM
Venumb's Avatar
ORIGINAL: CleanKat
I think you're referring to the remote signal wire...correct?
I went out to the garage and looked at my factory amp ( 02 Sport w/ premium sound system ). The Jag amp definitely has a different setup from the 750W Rockford Fosgate I have in my Jeep. Perhaps having someone flipp the power on and off your head unit while using a multimeter or test light to see which wire is getting juice will help you figure which direction you should go.
Old Oct 23, 2008 | 08:30 PM
christo's Avatar
oh the remote turn on. I started test wires until I found one that turns on and off with the ignition. They was I set my x up was to accept a new head unit down the road. So I placed my low level converter behind the dash, ran my rca's from there back and ran a remote wire connected to the ignition turn on wire for the radio.
I'm sorry dude the whole time you were saying signal I thought you weren't get anything out of you rca's.
Old Oct 24, 2008 | 06:42 PM
CleanKat's Avatar
I tried that. All the wires from the amphave power even with the stereo is turned off..
Old Oct 24, 2008 | 08:58 PM
CleanKat's Avatar
ORIGINAL: christo
Man I broke some plastic stuff on the Jag & I payed up the yin yang for that I would hate to brake anything trying to get signal from the ignition...that would surely cost an arm and a leg.
Come on guys I know that yall installed amps how did yall do it?
Old Oct 25, 2008 | 07:43 AM
Venumb's Avatar
It almost sounds as though you need some type of signal converter to trigger your amp. Have you checked out any audio forums? Lots of good info out there. I'm sure if you search hard enough you should be able to locate wiring diagrams for both your amps and head unit..if you don't already have them.
Old Oct 26, 2008 | 12:32 AM
CleanKat's Avatar
I actually did post in the audio forums and thus far it’s only had 19 hits with no replies... As far as doinga search, it was fruitless, Im a DIY type of guy and have do numers install myself, but the Jag is a different beast.
Old Oct 26, 2008 | 05:23 AM
christo's Avatar
Try looking behind the radio. Hook your tested to a groung and tap the wire and make not which have juice. Then turn the car to acc and see what has power. Then take one of the and run a wire to your trunk. If you want pm me with you telephone number and I can call you sunday afternoon.
Old Oct 27, 2008 | 05:13 AM
CleanKat's Avatar
ORIGINAL: christo
I was hoping that there would be an easier way as I have the OEM stereo/navi set up. I'm sure there is a **** load of harness/wires in the back of thestereo/navi...
Old Oct 27, 2008 | 08:20 AM
christo's Avatar
There has to be something in the trunk - but give those amps a couple days without running the car - you might find a dead battery.
Old Oct 28, 2008 | 09:13 PM
CleanKat's Avatar
Thanks for all your help christo...but Im baffled as to why no one haschimed in? There are about six different people with S-types with aftermarket amps but yet no one has giving me any info?[sm=feedback.gif]
