Anti-freeze odor in passenger cab
Old Oct 16, 2012 | 10:50 AM
larrymelton's Avatar
Default Anti-freeze odor in passenger cab
This car is starting to become a pain in the you know what. I had to replace the dccv, repair the ccm, fix restricted performance issue and now this. There is no visible leak of cooling fluid and the problem seems to come and go. Now I'm wondering what might be causing this problem. Anyone had any similar experience?
Old Oct 16, 2012 | 11:22 AM
joycesjag's Avatar
Sorry Larry but we don't know what your vehicle details are.
Would be helpful to put them in your signature as many members have done. Quite easy and only takes a minute, go to "UserCP", "edit signature" ad details "click save" POOF done and no more guessing for us.
Old Oct 16, 2012 | 11:24 AM
Default 2004 s type r
Sorry for leaving that out.
Old Oct 16, 2012 | 12:12 PM
tbird6's Avatar
The STR has lots of cooling hoses. Where are the red stains at? I would borrow a pressure tester and pressure test it when cold. If not already changed out the top tank has small plastic nipples that can break off pretty easy. That’s simple to change.
Hopefully it's not the hose under the super charger as that is very labor intensive to change. That hose usually puts the red stain on the back of the motor.
Old Oct 16, 2012 | 12:58 PM
JagV8's Avatar
Also, are you very certain it has to be antifreeze?
When does it occur?
waynepaulj
Oct 2, 2015 04:05 PM
hoodun
Oct 1, 2015 07:46 PM
Lawrence
XJ40 ( XJ81 )
Oct 1, 2015 08:36 AM
JagBrian
Oct 1, 2015 12:52 AM
