Antiroll bar link bolt seems a bit loose?
Old Jan 15, 2022 | 11:02 AM
animesis's Avatar
Default Antiroll bar link bolt seems a bit loose?
Should the bottom Anti-roll bar bush bolt have this much free movement? I've got a terrible knocking at the front , just replaced the front antiroll bar links and found the bolt was like this. I'm wondering if the bush has worn or the knock is elsewhere
File Type: mov
Old Jan 15, 2022 | 11:37 AM
NBCat's Avatar
With the anti-roll bar bush in situ, there should be no movement of the bolts.
Check the lower strut bushes as they tend to perish and can cause a knocking sound. Also check the bushes on the upper and lower suspension arms for wear, and the tie rod ends for any looseness.
Old Jan 15, 2022 | 12:18 PM
animesis's Avatar
The arm bushes are all ok, I replaced them all couple of years ago. The bush in the video is one of just 2 that I didn't replace, the other being the large bush on the end of the lower arm. I would hope the bushes haven't failed already as they were genuine Jaguar and cost an arm haha. Tomorrow i will try disconnecting the antirioll bar links and drive it around the block to see if the noise vanishes
Johnken
Sep 17, 2023 12:44 PM
NTL1991
XJ40 ( XJ81 )
Jan 24, 2022 03:48 AM
Johnken
Jun 14, 2019 06:51 PM
Thesicilianpr
Nov 10, 2013 09:20 AM
satwarez
Apr 8, 2011 10:34 AM
