Arm rest wont open
Old Apr 30, 2011 | 11:29 AM
hunter260's Avatar
Default Arm rest wont open
The center arm rest on my wife's 05 S-Type, 3.0, slides back, but wont open.
Any ideas?
Thanks,
hunter260 (Dan)
Old Apr 30, 2011 | 11:35 AM
STRaightJAGgin's Avatar
i have the exact same problem on my 03 STR. slides back, wont lift open.. i would force it, but rather not break anything.. anybody got a solution??
Old May 2, 2011 | 11:44 PM
phaelax's Avatar
You could try sliding something in from the front of it to see if something is blocking the latch?
Old May 9, 2011 | 03:34 PM
hunter260's Avatar
Default Arm rest
I was able to open it by rocking it to and from, while at the same time lifting it. I found that about 2/3rds the way down, there are two spring loaded clips on either side, and appears to be cam driven by a cable attached to the release button. When I lift the button, these don’t move. When I get the opportunity, I’ll remove the arm rest and see if I can repair it.
Old May 9, 2011 | 03:35 PM
hunter260's Avatar
I'll keep you in the loop.
Old May 9, 2011 | 05:15 PM
Michael Star's Avatar
It is a common issue. The part of the handle that releases the latches inside the armrest breaks. What you have to do is slide a screwdriver between the top of the armrest and the cupholder to release the clasps. At that point I just used some tape and tape them in the "in" position so it doesn't lock anymore.
Old May 10, 2011 | 01:01 AM
ill play around with mine tommorow.. if you get a chance to take yours apart hunter, pics of the fix will be greatly appreciated.
Old Aug 29, 2011 | 05:15 PM
Jag_man81's Avatar
Did anyone figure out how to fix this issue? I have the same problem.
Old Sep 2, 2011 | 10:01 PM
Jag_man81's Avatar
Wow, read this days ago and now I have this problem. Need help also would like to repair on my own.
Old Sep 6, 2011 | 04:46 PM
hunter260's Avatar
Default armrest
I managed to pop open the arm rest by pressing in the two clips on the sides. Once open, I found that the cables attached to the unlock button, had slipped out of their respective clips. With a tiny screw driver, I pushed the cables back into place. I’ll see how long this lasts. A replacement from Jaguar is $800. I hope this helps.
Old Sep 7, 2011 | 02:01 PM
SchultzLD's Avatar
Hummm, I have the oposit problem... sometimes mine will pop up if I lean on it wrong, or wont lock back after I shut it...(I keep it locked back 99% of time). Thx for the info, I'm gonna check my out to see if a simular issue is the cause.
Old Sep 7, 2011 | 04:32 PM
Mafioso's Avatar
yes I bought a replacement handle from the dealer, the pull cable on the right breaks out of the little holder from fatigue,
I know I posted this and the fix a while back.
Old Sep 8, 2011 | 03:21 PM
Jag_man81's Avatar
How do you remove the lid? Any pics or directions?
Old Sep 10, 2011 | 10:41 AM
Mafioso's Avatar
Rock the lid while gently pulling up. There are torx screws that,hold the safety cover remove those then there are 2 torx that hold the handle to the lid the cables are a serious pita to remove but doable ir was a 1hr job tops
Old Sep 23, 2011 | 04:38 PM
hunter260's Avatar
My repair didn’t last, so I had to replaced it.
Jandreu
Jun 30, 2022 03:10 PM
RaceDiagnostics
Sep 13, 2015 02:22 AM
Harry Dredge
Sep 3, 2015 03:04 AM
Harry Dredge
Sep 2, 2015 02:26 PM
