automatic powerfold mirrors by key-fob buttons
I am in the UK and have come up with a really nice little device as an add on.
If you have power-fold wing mirrors already fitted to your car and would like them to open and close automatically with your key-fob then I now have a solution for you.
Double push the lock button on your key-fob and they fold close, press to unlock the vehicle and the mirrors unfold. No more swearing half way down the road or going back to the car at the car park as you forgot to fold them in.
All controlled by a small black box that snuggles in nicely just behind the wiring harness connector block behind the drivers door card.
The fitting procedure for the unit is very straightforward indeed and takes around half hour.
Firstly the drivers door card needs to be removed. Once removed you need to splice in just 5 wires that's all and they are all located just behind the door card and are all very easy to access.
Nestle the small brain in as described above. Door card back on and all finished.
You can still use the manual button if you want and can also fit a simple on/off switch if you feel that you would need to turn the system off for any reason so its a very versatile unit.
Brilliant little box and a great design.
Price is forty quid (uk) plus a fiver for postage. (check postage for the US)
Great little mod.
Just PM me if you are interested.
Great little mod.
I have an 08 XJL it does not come with power fold mirrors. Does anyone know if the wiring is there to add the mirrors and the master switch? I already have programed my car and I have the option to turn it on or off via my Menu screen.
thanks so much for any help
Jose
Jose
PolkNole
Oct 21, 2025 02:22 PM
