Auxiliary water pump
Old Dec 11, 2015 | 06:36 PM
kaotikd's Avatar
Default Auxiliary water pump
I have 01 s-type 4.0 and im getting no power to the auxiliary water pump, the fuse is good and i switched the relay for one that is known to work.
Does the pump kick on when the heat is turned on? I'm trying to work out a heating issue. It doesn't have good heat even when its operating temp, it has new dccv. But when i went to test the pump it had no power.
Old Dec 13, 2015 | 10:13 AM
Gus's Avatar
Gus
It feeds from #1 10afuse in the front distribution fuse box. If power is not available then you need to look at the Air Condition Control Module or the A/C Heat head unit in the car. Looking deeper into the problem it could also be a Temperature sensor and this car has 4 of them and the one universal to both I think is the Solar and In car but that is my best guess.
Old Dec 16, 2015 | 03:06 PM
kaotikd's Avatar
I replaced the heater control module and its working fine now and have great heat.
thanks for the advice!
goodgame
Jan 4, 2016 06:51 AM
ziggydrives
Dec 10, 2015 08:57 PM
Luke5324
Dec 5, 2015 01:50 PM
DerekShiekhi
Dec 3, 2015 07:21 PM
DuhCar
Nov 23, 2015 09:49 PM
