Baffled
Old Sep 13, 2017 | 11:30 AM
Jaw Godsquad's Avatar
Default Baffled
New to the forum. I have a 2003 Jaguar s type 3.0 v6 at first I was getting 11 obd codes. I changed the spark plugs and coil packs now I'm down to 7 codes and have no idea what to do next. Po302, p1314, p1316, p0352, p1647, p0352, p1647, & p1000. I checked for vac leaks with carb spray and added full cleaner. The vehicle starts find engine light is on and it goes right into restricted performance. In stop position there is a wobble vibration. In drive it won't accelerate past 3 rpm when you give it gas. You can gradually get up to speed with light press on gas. There is a slight jerk in shifting in lower gears and at high speed after a long drive the engine will bog down. The engine light will flash off and on during driving. Need suggestions
Old Sep 13, 2017 | 02:30 PM
stevep10's Avatar
Welcome to the Forum, and your nightmares
Firstly, have you downloaded and studied the JTIS manual that is free on here? It will have loads of very useful information on your car, and step by step guides.
Secondly to those codes
Click on this link, scroll down to the end of post #2, click on the PDF link and it will give you all the info you need on your DTC's, and more.
https://www.jaguarforums.com/forum/s...-codes-184315/
Looks like you have some work to do................
Old Sep 13, 2017 | 03:05 PM
Originally Posted by Jaw Godsquad
New to the forum. I have a 2003 Jaguar s type 3.0 v6 ...... Need suggestions
Welcome to the forum Jaw Godsquad,
I've moved your question from General Tech Help to S-Type forum. Members here with the same model will be able to help.
Old Sep 13, 2017 | 04:54 PM
JagV8's Avatar
Best thing is look the codes up in the (free download) codes PDF / workshop manual - or use forum Search. You get all the known causes.
P1647 tends to be the actual sensor.
P0302/P0352 may point to coil or wiring as the most likely.
P1314/P1316 - don't keep driving without fixes or you'll be replacing the cat. conv.(s)...
Flashing MIL = cat conv damage occurring.
Do not keep driving like this!
Old Sep 14, 2017 | 12:52 PM
Jon89's Avatar
The two factory IMT O-rings at the passenger-side rear of the engine (IMT = Intake Manifold Tuner Valve) on the V6 engines are notorious for failing and allowing air leaks. These factory IMT O-rings are yellow in color. Replace them with the new-and-improved IMT O-rings that are green in color, and I will bet that quite a few of your trouble codes will disappear. There are many threads here on the forum that will guide you through the replacement process. Search using "IMT O-ring short route replacement" as your search phrase and you will be able to read everything you need to know on how to do this job....
