2003 S Type 4.2 codes
Old Jun 21, 2017 | 08:35 PM
Joshua Silva's Avatar
Exclamation 2003 S Type 4.2 codes
I have been working thru the forums and trying to find some answers for my jag.
I am getting codes
P 0328
P 0420
P 1000
The owner before me changed the battery, plugs, coil paks and fuel filter after running 2 bottles of injector cleaner in it with 1/4 tank of gas. I filled the car and drove it 80 miles and most of the monitors except 1 reset.
The restricted performance light and engine light have been on, It did shut off by itself for about 10 miles but is back on. I am thinking I need to replace the Bank 1 Knock sensor, any thoughts and where is the best place to get these that won't brake the bank.
I did also have the air bag light on, the code brought me to the driver side re tractor I took the seat out and went thru every connection plugged it back in and wha laa no Air Bag light. so one small victory.
Old Jun 21, 2017 | 08:56 PM
motorcarman's Avatar
X202 Powertrain DTC Summaries – OBD II Quick Reference Diagnostic Guide
OBD SYSTEM READINESS – ENGINE MANAGEMENT
If DTC P1000 is flagged after DTCs have been cleared, all engine management OBD diagnostic monitor drive cycles HAVE NOT BEEN COMPLETED.
If DTC P1111 is flagged after DTCs have been cleared, all engine management OBD diagnostic monitor drive cycles HAVE BEEN COMPLETED.
OBD SYSTEM READINESS – TRANSMISSION
Use WDS Datalogger “TOTAL NUMBER OF DTC SET” to determine if transmission OBD monitoring has been completed.
OBD “TRIPS”
The OBD system defines 1 TRIP as an ignition cycle (ignition key OFF; wait 30 seconds; ignition key ON) plus a minimum engine coolant temperature increase of
22 °C (40 °F) after which, the engine coolant temperature has to reach a minimum of 71°C (160 °F).
OBD DIAGNOSTIC MONITORS
The Engine Management and Transmission Control systems are continuously checked during vehicle operation by the Engine Control Module (ECM) and Transmission
Control Module (TCM) on-board diagnostic (OBD) facilities. Powertrain OBD incorporates seven diagnostic monitors. Each monitor has an associated group of DTCs.
The diagnostic monitors will complete the diagnostic test(s) if a specified service “drive cycle” is carried out.
The seven diagnostic monitors are as follows:
– Heated Oxygen Sensors Monitor
– Adaptive Fuel Monitor
– Misfire Monitor
– Catalyst Efficiency Monitor
– Evaporative System Monitor
– Exhaust Gas Recirculation Monitor
– Comprehensive Component Monitor (Engine Management / Transmission)
DIAGNOSTIC MONITORS DRIVE CYCLES
Technicians can ensure that an OBD Monitor drive cycle is completed and that all or specific components have been checked by completing a specified drive cycle.
Use the following service drive cycles to confirm that the components and subsystems covered by the Diagnostic Monitors are operating correctly.
HEATED OXYGEN SENSORS MONITOR DRIVE CYCLE
Upstream (Universal) oxygen sensors:
1 Engine OFF; cooling fans inoperative > 20 seconds.
2 Start engine and bring to normal operating temperature > 82 °C (180 °F).
3 Drive the vehicle between 3000 – 4000 rpm in 3rd gear at a steady speed. Lift foot completely off accelerator and coast to a stop within 30 seconds. Do not touch
accelerator pedal for 4 seconds after coming to a stop.
4 Repeat step 3.
5 Idle engine for 11 minutes.
Downstream oxygen sensors:
1 Start engine and bring to normal operating temperature > 82 °C (180 °F).
2 Drive the vehicle steadily between 48 – 97 km/h (30 – 60 mph) for 10 minutes.
3 Drive the vehicle above 3000 rpm in 3rd gear at a steady speed. Lift foot completely off accelerator and coast for 30 seconds.
Oxygen sensor heaters:
2 Idle engine for 3 minutes.
ADAPTIVE FUEL MONITOR DRIVE CYCLE
2 Idle for a minimum of 10 minutes.
MISFIRE MONITOR DRIVE CYCLE
1 Record flagged DTC (s) and accompanying WDS DTC Monitor freeze frame(s) data.
2 Fuel level > 25%.
3 Start the engine at a coolant temperature lower than the recorded freeze frame value (from Step 1).
4 Drive the vehicle to the recorded freeze frame conditions for 4 minutes. If CHECK ENGINE MIL flashes, lower the engine speed until the flashing stops.
Note regarding misfire monitor DTCs:
If, on the first trip, the misfire is severe enough to cause excess exhaust emission, the individual cylinder DTC plus DTC P1316 will be logged. The CHECK ENGINE MIL
will not be activated. If the fault reoccurs on the second trip, the individual cylinder DTC plus DTC P1316 will be flagged, and the CHECK ENGINE MIL will be activated.
If, on the first trip, the misfire is severe enough to cause catalyst damage (more severe than excess exhaust emission), the CHECK ENGINE MIL will flash while the
fault is present and the individual cylinder DTC plus DTC P1313 (bank 1), DTC P1314 (bank 2) will be logged. When the fault is no longer present the MIL will be deactivated.
If the fault reoccurs on the second trip, the CHECK ENGINE MIL will flash while the fault is present and the individual cylinder DTC plus DTC P1313 (bank 1),
DTC P1314 (bank 2) will be flagged. When the fault is no longer present the CHECK ENGINE MIL will be activated.
CATALYST EFFICIENCY MONITOR DRIVE CYCLE
2 Drive the vehicle in a steady state condition between 1300 – 3000 rpm without stops or starts for a minimum of 5 minutes.
EVAPORATIVE SYSTEM MONITOR DRIVE CYCLE (OBD II ONLY)
1 Ensure that fuel filler cap is fully closed (minimum three clicks).
2 Fuel level > 30% and < 85%.
3 Using WDS, perform ECM DTC Clear (even if no DTCs are flagged).
4 Drive vehicle for a minimum of 2 minutes, and until engine is at normal operating temperature.
5 Using WDS, ensure that the EVAP Canister Purge Valve is operating by observing “PURGE VAPOR MANAGEMENT VALVE – DUTY CYCLE”. If the valve is not
active, ECM adaptions have not been learned. Conduct a “green ECM” Drive Cycle as described in Technical Service Bulletin.
6 Drive vehicle to the road where the EVAP System Drive Cycle will be conducted. Stop vehicle and switch OFF the ignition. Leave ignition OFF for 30 seconds,
then restart the engine.
7 Accelerate briskly to 80 km/h (50 mph) ensuring that the engine speed reaches a minimum of 3500 rpm for a minimum of 5 seconds.
8 (0.040 inch EVAP Test) View WDS “PURGE VAPOR MANAGEMENT VALVE – DUTY CYCLE”, “CANISTER CLOSE VALVE – VAPOR RECOVERY SYSTEM”, and
FUEL TANK PRESSURE – VAPOR RECOVERY SYSTEM”. Avoiding high engine loads, drive the vehicle steadily between 65 km/h (40 mph) and 100 km/h (60
mph). Avoid driving conditions that will produce excessive fuel movement. WDS should give an indication that the test is active (it may take up to 30 minutes
before the test will initialize). When the test has initialized (EVAP Canister Close Valve CLOSED), it will take approximately 90 seconds for the test to complete.
9 (0.020 inch EVAP Test) Continue driving vehicle as explained in Step 8 for an additional 10 minutes.
10 Gently coast the vehicle to a stop. Allow the engine to idle for 2 minutes and view WDS “PURGE VAPOR MANAGEMENT VALVE – DUTY CYCLE”, “CANISTER
CLOSE VALVE – VAPOR RECOVERY SYSTEM”, and FUEL TANK PRESSURE – VAPOR RECOVERY SYSTEM”. WDS should give an indication that the test is
active. When the test has initialized (EVAP Canister Close Valve CLOSED), it will take approximately 90 seconds for the test to complete.
11 If the 0.020 inch EVAP Test is not activated, the purge system vapor concentration may be too great. To reduce the vapor concentration proceed as follows:
12 Drive the vehicle for an additional 30 minutes avoiding driving conditions that will produce excessive fuel movement. Repeat Step 10. If the 0.020 inch EVAP
Test is still not activated, repeat the Drive Cycle from Step 6.
13 Using WDS, check for and clear flagged DTCs.
EXHAUST GAS RECIRCULATION MONITOR DRIVE CYCLE
2 Drive the vehicle in 3rd gear at 2500 rpm. Maintain a steady speed for 1 minute, then lift foot completely off accelerator and coast for a minimum of 10 seconds.
COMPREHENSIVE COMPONENT MONITOR ENGINE MANAGEMENT DRIVE CYCLE
To avoid unnecessary complexity, a single comprehensive engine management drive cycle has not been developed for S-TYPE. Refer to the individual DTC for specific
drive cycle / monitoring conditions.
COMPREHENSIVE COMPONENT MONITOR TRANSMISSION DRIVE CYCLE
To avoid unnecessary complexity, a single comprehensive transmission drive cycle has not been developed for S-TYPE. Refer to the individual DTC for specific drive
This is taken from the DTC guide.
File Type: pdf
Old Jun 22, 2017 | 12:56 AM
JagV8's Avatar
It really really wants working sensors.
P0328 may be the sensor or its wiring etc. (Don't know access etc on 4.2 but see free download workshop manual.)
SNG are forum sponsors with a discount for parts...
Old Jun 24, 2017 | 08:31 AM
Vin # SAJEA01UX3HM84660
Old Jul 1, 2017 | 08:10 AM
So I went thru the readiness codes and engine light still on. I took the intake off replaced Both Knock sensors (because they are a Bear to get at) and also replaced the intake manifold gaskets. Back together engine light off still have to set some monitors. And now to tackle my non working Wiper Motor. I check all three fuses and they all om'ed out I am going to check power at the connector then I assume the motor next.
Old Jul 2, 2017 | 12:34 PM
clubairth1's Avatar
Community Influencer
Good job on the repair! And for giving us an update.
Hard to tell what the solution was to so many problems without feed back.
Old Jul 4, 2017 | 11:31 AM
So I have gotten rid of the Air bag issue the knock sensor issue and now I am onto the P0420 Code issue. All my monitors have been sent but one. I had 6 set yesterday and as soon as the 7th set the engine light came on and gave me the P0420 code. Which points to the catalytic converter. I am assuming I should buy the O2 as well. And the P0420 is the passengers side correct ? Jag and ford the firing order puts #1 at the passengers side front. Any suggestions on this ? When I put my code reader on it will only read Bank 1 Sensor 2 the others say not supported. But when I go through the scan side not the diag side I can test and pass all the 02 sensors. The drivers side downstream is also rounded off like someone tried and failed to remove it. Still haven't touched the Wiper issue ( car is not draining power at all )
Old Jul 4, 2017 | 11:50 AM
Ducmon's Avatar
Hi,
If you use this program you can check both O2 sensors.
trail version here http://www.outilsobdfacile.com/software-eobd-facile-elm327.php. works with an elm 327.
you have to use broadband 02 for sensor 1 then you can compare the outputs from the O2 sensors before and after cat.
This video shows you what you have to look for.
I use a cheap scope which works on a laptop when I need to go into the possibility of future failure (second half of video).
https://m.youtube.com/watch?v=vyVnhCIMDnw
Old Jul 16, 2017 | 03:14 PM
Update Rear brake issue resolved. Took caliper off and found one side completely rusted, not letting the pads press evenly. Cleaned entire assembly and lubed seems to be working ok at this time.
Wipers - Well not such good luck I took the assembly out and found it to be pretty sticky. I thoroughly cleaned and then re lubricated the it and it rotates flawlessly. I also did have to clean one of the spray nozzles it was clogged up. I still cannot get the motor to turn on. I check all the fuses and connections even took the fuse box apart to make sure there wasn't any corrosion or loose connections and still nothing. When I turn the wipers on I can the fuse F-12 I believe turn on but nothing more. Any other suggestions would greatly be appreciated.
