Battery light on, everything else OK
Old Jul 10, 2016 | 06:22 AM
sadimco's Avatar
Default Battery light on, everything else OK
After the faulty alternator was replaced, the battery caption remains on, but everything is OK
Old Jul 10, 2016 | 06:55 AM
kr98664's Avatar
Ooh, this one is easy. Was an aftermarket replacement installed? The regulator inside the OEM version has a special extra circuit for the battery light. Aftermarket versions, even if charging properly, don't have this capability.
The light isn't controlled directly by the alternator, unlike most vehicles. Instead, special OEM circuitry in the alternator's internal regulator will monitor the charging output and send a valid signal if all is good. The receiving computer (sorry, don't know its name offhand) turns on the warning light any time the valid signal is not present.
I think it's possible to swap the regulator from the failed OEM alternator into the aftermarket unit. As long as the original regulator is still good, that should take care of the missing valid signal.
Old Jul 10, 2016 | 06:56 AM
Datsports's Avatar
Oh I have heard some/all after market replacement alternators will not put out the charge light . Somthing to do with non compatable ic reg .
The thing to do here is not to throw out the old alty and get it overhauled . Then swap them back ,
Old Jul 10, 2016 | 10:57 PM
Robinb's Avatar
I....didn't....know....that! Thanks you two guys.
Old Aug 5, 2016 | 04:49 PM
jazzwineman's Avatar
Default Replaced with AfterMarket and No Light
This morning I awoke to the battery light being on in my car. Have a 6 month high end AGM battery but tested anyway with car running and was at about 12.03 volts and amps were in negative. Knew it was the alternator and more specifically the regulator. Went and was able to get one at O'Reilly. Did not know if the l signal would get sent or not, but after installation, everything worked fine and no battery light and it was a re-manufactered one. Of course, I could have been lucky on the parts inside that were redone. However much cheaper than giving money to the arrogant thieves at the Jag Dealership. Here is a link and it works fine.
Ultima 11199 - Alternator | O'Reilly Auto Parts
Tom in Dallas/Plano
2005 S-Type 3.0 91k
Stevie b
Aug 15, 2016 06:29 PM
jagxkrtoofast
May 19, 2016 04:23 AM
AlexJag
May 17, 2016 01:00 PM
NathanDD6
May 8, 2016 02:11 PM
tat2dkjn
Apr 15, 2016 02:29 PM
