Battery problem
Old Mar 2, 2009 | 09:20 PM
scottymack's Avatar
Default Battery problem
I have been on this site looking for hours. This is probably the area i need to talk about.(And yes probobly your battery since when they loose reserve power, if power gets to a certain level while sitting the car wakes up electracally and runs the battery down the rest of the way, everytime a battery is run down it looses approx 50% of reserve power). I have a 2000 S type 4.0 have had it since 2002. @ years ago original battery started to crap out. Called Jaq guy he said get Advanced auto Titanium replacement. After one week the new battery was dead in the morning. Charged it and dead next morning so on and so on... Took to Jaq guy,had car for 2 weeks. Said he "reset the relays" and $150.00 later it worked fine for over a week. Then all of a sudden dead again. now dies in less than 6 hours. He said the relays are satying on ( not going into sleep mode). I just bought another new battery and car worked fine for over a week and once again dead in the morning. Who can help me with this one????????
Old Mar 3, 2009 | 01:11 PM
djdex's Avatar
One of your modules is staying awake is my bet, the RECM is a favourite as it's in the boot/trunk and can get affected by water (another standard issue). Sadly on your own it's not easy to test unless you can swap it out for another.
Old Mar 3, 2009 | 06:27 PM
scottymack's Avatar
Default meter test
Thank you for your comment. I think so too. last night I put a meter in line and saw a 4 amp draw. I came back 30 minutes later and it was down to 1.5 amps. I then pulled each fuse one by one to see if i had a specific draw and no change from any fuses except when I pulled the # 20 fuse interior, GEM. Then it went to .7amps, that is all i know to do. Any other tests I can do????
Old Mar 4, 2009 | 01:23 PM
djdex's Avatar
It's very difficult to get true readings for the car when it's fully asleep, as even unlocking it reawakes it. I wonder if you could trick the boot switch into thinking it's closed, leave it open and take readings after 1/2 hour with & without the RECM plugged in?
Old Mar 4, 2009 | 07:36 PM
jag_genius's Avatar
Have had REMs fail and have had front gem stay on keep communications up with gem and they both keep the 4 relays on. There's about thirty different things it can be. Three most found are the gem failing in the trunk . 2 ignition barrel not fully turning off which keeps half the car awake . 3 fem module missing it's keep alive power due to front harness having corrosion . Also have seen door modules stay on . Also near battery there is a white connector this corrodes and keeps the ignitin barrel . Hope this helps
Old Mar 5, 2009 | 08:17 AM
scottymack's Avatar
Thanks again for the help. I had taped the trunk switch closed so the light stayed off and left door open so lights would turn off before testing. Can you provide me with the location of these modules so i can unhook it and test again?
I did see that single wire in the trunk near battery and it does not seem to have any corrosion. Trunk is like new, no moisture. Also you said "4" relays and it seems that 2 of the relays in the trunk are staying warm. Can you provide me the relay numbers so I can test the correct ones?
Old Mar 13, 2009 | 02:59 PM
scottymack's Avatar
still dead (((
Old Mar 22, 2009 | 05:28 PM
marktmv's Avatar
Were you able to resolve this problem? I seem to be having the same issue. All of the sudden the battery lost all of its juice in the matter of two days.
Old Mar 23, 2009 | 08:17 AM
scottymack's Avatar
I am in the process of eliminating the body control modules. i took it to the local Jag tech and he is swapping them one at a time. i will send a follow up when comanswer is found...
Old Apr 15, 2009 | 08:11 PM
Brutal's Avatar
and the spec is less than 30 milleamps. and if I remeber right its within 45 minutes. But there is a whole diag proceedure that has times and specs on stages of volatge drops and times. just pull fuses till you get the one pulled that lets the car go to sleep....And 1 that really threw me about 4 years ago was an ignition switch...But the good news is at least your car is consistent, and youre not chasing a intermittent fault anylonger
Old Apr 16, 2009 | 08:22 AM
scottymack's Avatar
Thanks for the input,
The car is back at the dealer for 5 weeks at this point. he has swapped out the body control mods and its still dying. i have heard of the keyswitch but have not swapped it. Is is common for the radio to come on when you hook the battery back up? the radio is off and only shows the clock and the key is not in the ignition but the am radio comes on when i hook the battery cables back up.
Old Apr 16, 2009 | 09:16 AM
Brutal's Avatar
Not that ive ever seen
99xk8guy
May 28, 2024 09:36 PM
jdzubas
Oct 4, 2015 09:14 AM
jehart49
Sep 12, 2015 05:36 PM
OkieTim
Sep 8, 2015 04:48 PM
mcdutch
Sep 4, 2015 03:38 AM
