Best Model Year S-type Supercharged (STR)
Old Jul 14, 2012 | 11:00 AM
JagV8's Avatar
Originally Posted by Michael Star
Ya but I could have sworn I read somewhere that the increased grip actually created a bit more horsepower since it wasn't slipping anymore on the supercharger.
The belt only slips (if it does) when cold. I don't believe it slips once warm. If it did the belt would wear out quickly. They don't.
Old Jul 14, 2012 | 09:14 PM
Tijoe's Avatar
Originally Posted by MyBlackCat
Hey Tijoe, great thread, nice to have a friendly debate on here from time to time,with no right or wrong answers. All STR's are great.. get one FAST.
My question to you.. What happened to your project of throwing a new Camero engine in a 2000 S Type? You seemed to have thrown tons of money at it and I am hoping that you have not given up. Or is the STR part of the mix now?
You had mentioned suspension and brake upgrades to the old car but are you now going in a different direction.
Let us know.
Yes, I am still plugging away on the car. I keep meaning to add an update.
I have been focusing on suspension and brake upgrades. Since I work 300 miles away from where the car is, progress has been very very slow.
Back to this thread... Another positive for newer STRs, is that if the car is older than 7 years old, it is much more difficult to get a car loan at the lower interest rate, and terms longer than 3 years. There is a 2004 STR I would like to purchase, (8 years old) but I want to finance it rather than use up all my cash. Besides, interest rates are so low right now, I'd rather have a payment.
Regarding buying another S-type, my 97 XJ6 is getting tired and I want a new steed to replace it.
THIS IS A FANTASTIC THREAD!!!! Keep up the comments!!!
Old Jul 15, 2012 | 05:28 AM
Sslah's Avatar
Originally Posted by JagV8
Which cooling issue?
fog lights block the air tho the front facia. they removed the fog lights for that reason on 05+
Old Jul 15, 2012 | 08:50 AM
JagV8's Avatar
But what cooling issue? There are no problem reports of any on here, are there?
Old Jul 15, 2012 | 10:00 AM
clubairth1's Avatar
Community Influencer
HTML Code:
No they were removed because Jaguar changed the position of the engine oil cooler on the STR. The 2005 and up STR's have two separate oil coolers mounted where the fog lights were on the 2003-2004 STR's. The older STR's had the oil cooler sandwiched in with the radiator, A/C condenser and P/S cooler. It was just getting too much so for improved engine oil cooling they upgraded to the two separate units.
Old Jul 15, 2012 | 11:37 AM
Blaq Cat's Avatar
I love the styling from"05"-"08" in my opinion, The re-designed front bumper, the tail lamps that sit flush with the curves in the rear but the best part is how the hood has a much broader V shape that spans out to both corners of the hood, I do wish they had kept the brembo breaks though they looked a hell of alot nicer and sportier than the ones they replaced them with. I was thinking of getting some used brembo R brakes off ebay but I usually like to keep the original equipment on mine especially since the "07" model didn't have em.
Old Jul 15, 2012 | 12:49 PM
steadicam's Avatar
Originally Posted by Under Pressure
I'm not so sure . I think Motor Trend is a very reputable publication, and I am pretty sure they get their specification information directly from the manufactorer. Besides, variable valve timing is ancient technology, even in 2003. For instance, back when I was younger and a bit more handsome (lol), I used to have a 1993 model year Honda Prelude VTEC. The "VTEC" is an acronym for "Variable valve timing and Lift electronic control."
I have an 05 STR and it absolutely does NOT have VVT but my 2003 did. The engineers at the time said they saw no improvement in HP with the supercharged engine. I guess in 06 six they figured out it was worth something to add it to sc motors.
Old Jul 15, 2012 | 01:38 PM
  #28
JagV8's Avatar
The Technical Guide specifically states it reduces emissions. The emissions laws got tighter so this seems to be the reason. At the same time they added SAIR (secondary air injection), again to meet tougher emissions laws. I doubt this matters to anyone thinking of buying an STR...
Old Jul 15, 2012 | 01:55 PM
bfsgross's Avatar
06 was the first year for STR VVT. IMHO, the 03-04 are unique with their more agressive styling compliment of Brembo brakes, driving lights, unique rear lamp covers, and spoiler that spanned across the rear trunk lid.
Old Jul 15, 2012 | 01:57 PM
  #30
JagV8's Avatar
Yes, I meant the Technical Guide for 2006. Ref JTP1050
Old Jul 16, 2012 | 08:09 PM
  #31
Tijoe's Avatar
Will the newer Aluminum hood fit on the 2000- 2004 S-types?
Old Jul 17, 2012 | 07:10 AM
  #32
clubairth1's Avatar
NO. For 2005 they changed the front fenders and hood and grille. It's not much but it is different.
Old Jul 17, 2012 | 07:31 AM
  #33
JOsworth's Avatar
Yes, and No... They really changed a bunch up there. You would need to change the front fascia as well. Now, I don't know if the front supports changed. Now the two things that didn't change and may make it work are the headlamps and front fenders. So, that means that from the outside at least, the hood and fascia will line up with the fenders... If they will actually bolt up is another question.
Edit: Depending on what you are looking to do, this may make a difference as well. In 2005 the washer nozzles were moved from the hood to the wiper arms. So, you would have to either adapt the new wipers to an older car or drill holes and mount nozzles....
Here is a 2005 and up nose shot off the net...
And the earlier car...
While the fascias look the same, note that the grill mounting and angle is totally different.
Also, keep in mind that Jaguar did a major rework of the car for 2002.5 / 2003 (depending on market). Most of those changes were invisible to the naked eye but resulted in a tighter chassis and better fit and finish. Not to mention that they also redid the suspension and stuff. Probably one of the best indicators of what changed is an accurate body repair manual. If they list a different part for the 03 and up car, then it changed. And like many others have said... the 05 and up cars were mostly cosmetic changes. And.. yes... VVT was around on the naturally aspirated cars before 06 but NOT on the supercharged until 2006.
Another trivial note.... 2005 was the last year for body color trunk trim. All future R's had chrome trim across the trunk lid. So, since 05 was a refresh, it was the only year like that.
Last edited by JOsworth; Jul 17, 2012 at 07:35 AM. Reason: forgot another detail...
Old Jul 17, 2012 | 01:01 PM
  #34
tbird6's Avatar
Thanks for that!! i stand corrected, the front fenders did NOT change with the 2005 model upgrades.
Old Jul 17, 2012 | 08:44 PM
  #35
Sslah's Avatar
as far as i can tell, the changes were front bumper(parking assist were added), fogs lights removed, new design aluminum hood(no windshield washer spray were hidden on the wipers), new 18 Vulcan wheels(same size) , new rear bumper, new tail lights(i prefer the old one), revised trunk lid, new spoiler(shorter) interior : new gauge cluster. welcome to add if i miss anything
Old Jul 17, 2012 | 08:59 PM
  #36
JOsworth's Avatar
LOL! I thought for sure they changed the fenders as well. My first "find" about that is when I parked my 05 next to an 03 at the dealer. And sat there checking each line.... Even the little curve up by the A pillar is exactly the same..Mike, the service manager thought I was nuts... The one question I don't know though, are all the mounting points underneath the same? I bet some of that stuff changed in 03 with the refresh... so, you may be able to get away with a swap of 05 parts on to an 04, but would they work all the way back to 2000?
Old Jul 17, 2012 | 09:14 PM
  #37
JOsworth's Avatar
The rear quarters (wings) are also totally different. The only carry over panels were the window frames, roof, fenders(front wings), and doors. I'm pretty sure the plastic sill covers stayed the same as well as the glass. There were a few different seats used through the years, but those are real hard to tell the difference.
Old Jul 18, 2012 | 03:47 PM
  #38
JagV8's Avatar
The 06-08 also had 20 more HP. Most guys will debate that as some Government wizardry but it was added none the less. VVT was also added which might be where the extra horses comes from.
Aha - finally noticed Jahuar brochure says the 2008 model STR has 395 i.e. no extra HP.
Here's the first place it's in the brochure. (The whole PDF is too large.) It's also in a table later in the brochure, same 395.
edit: looks like a full brochure is http://jaguar.brochures.tagworldwide...80_en_OINT.pdf
File Type: pdf
Old Jul 18, 2012 | 06:07 PM
  #39
MyBlackCat's Avatar
Go back and read my post #20.
Since you can see All the worlds brochures I am sure you can pull up the US version of 06 That I have in my hand. 400 HP on my stated page.
The one from 08 must be British and says 395PS what ever that is.
Take a look .
Old Jul 18, 2012 | 06:16 PM
  #40
JagV8's Avatar
Whatever you do it's not 420 so an extra 20 did not appear.
PS is a standard unit. Try it in Wolfram's Alpha and choose which kind of HP you like
