Blend door stuck
Old Jul 30, 2018 | 09:13 AM
seejayp12's Avatar
Default Blend door stuck
The a/c on my '05 s-type is blowing warm air on one side and i'm told the blend door is stuck and has to be replaced. Does anyone know where it is located on the car?
Old Jul 30, 2018 | 10:14 AM
kr98664's Avatar
I'll hazard a wild guess whoever told you that has never worked on an S-Type. There is no blend door for temperature control. The door actuators control the air source (fresh or recirc) and exit point (floor, dash, or defrost), but that's it. Temperature for each side is controlled by adjusting the coolant flow through a split heater core.
More details than you probably care to know are here:
https://www.jaguarforums.com/forum/s...ol-how-185002/
Run the tests in post #2 to see if your DCCV is sticking open on one side. That's the valve which controls coolant flow to each side of the heater core
Digital Will
Feb 21, 2026 05:58 PM
jaguarxfv8
May 3, 2017 06:54 AM
Paulo Santos
Oct 14, 2016 08:21 AM
michaelodonnell123
Oct 13, 2016 12:06 PM
Don B
General Tech Help
Nov 9, 2015 12:59 PM
