Bluetooth head scratching
Old Sep 18, 2009 | 09:20 AM
Toller's Avatar
Default Bluetooth head scratching
2005 S-Type 3.0
I have a Blackberry 8330 which is listed on the Jaguar site as being fully compatible.
When I start the pairing process, both phone and screen respond as they should. After pairing, the phone shows "Connected" and the car shows "No Service".
Sometimes when I switch to "Audio" on the screen and then switch back to the phone, it works.
Sometimes when I dial a number on the screen, it works.
All other times, it shows "No Service"
The phone shows that it is paired and that it is connected.
Any ideas?
Eric
Last edited by Toller; Sep 18, 2009 at 11:22 AM. Reason: Correct use of console and screen for clarity
Old Sep 18, 2009 | 10:32 AM
JOsworth's Avatar
Maybe a dumb question, but where is the phone while you are trying to use Bluetooth?
If I'm not mistaken, the Bluetooth receiver is under the console storage box. Maybe there is something that is interfering with it's ability to receive data. The phone may be able to "see" the receiver but the receiver intermittently is loosing the phone. Try leaving the phone in the console???
Old Sep 18, 2009 | 11:21 AM
Toller's Avatar
When I try to use the phone, it is sitting in the ashtray just forward of the console....maybe 18 inches.
I forgot about the upolstered console. I was using the term to mean the screen in my first message. I've edited it so that it now makes more sense. Thanks.
Eric
Old Sep 18, 2009 | 02:42 PM
JOsworth's Avatar
OK, sounds like the phone is close enough to the receiver. I would try someone else's bluetooth compatible phone and see if you have the same trouble. It may be a problem with the bluetooth module, the phone, or a software issue with the radio. If another phone works fine then I would say it's either your phone or more than likely an issue with the software in the radio.
Old Sep 18, 2009 | 03:25 PM
phd12volt's Avatar
make sure you update to the 4.5 version software on blackberry . com --- there is a bluetooth patch in there.
Jagzzz
Aug 8, 2021 02:45 PM
X308XJR
May 20, 2019 06:50 PM
LnrB
Oct 13, 2015 12:45 AM
42Ajd
Sep 26, 2015 07:04 PM
