Brake rotor question
Old Apr 15, 2010 | 08:53 AM
JagV8's Avatar
tbird6 - I reckon I owe you that at least
Old Apr 15, 2010 | 09:17 AM
androulakis's Avatar
Originally Posted by BRUTAL
NO theyre not, no more random than thinking any Jaguar "R" model came with Brembo brake standard(they dont)
I would always measure, there is no rhyme or reason to what Jag does at times. I have over the years seen stuff on cars theyre not supposed to have, and others that were supposed to and don't
That said, you can always use 300mm disc on the 320 sized but not the other way around. Ive seen it done believe it or not...The outer pad misses the rotor by 20mm, when you look for material left youll see a nice big ridge on unused pad
Funny thing is, no one has ever complained about the reduced braking or noticed
Brutal,
I guess the point of my question was, if you have 300mm rotors, and want to "upgrade" to 320mm, besides the actual rotors, what else do you need? The calipers and pads remain the same I assume, but what relocates the caliper to accomodate the larger rotor? A caliper carrier bracket or something?
George
Old Apr 15, 2010 | 12:51 PM
Leedsman's Avatar
I do believe Jaguar were the first road car in the world to use disc bakes and they were a Dunlop invention. Am I right here? Abt. 1953.
Leedsman.
Old Apr 20, 2010 | 12:50 PM
Mafioso's Avatar
Mine has 300mm rotors I'd like to take advantage of the 320mm
That years had the 320mm standard?
Old Apr 20, 2010 | 12:53 PM
That's what I was trying to ask Brutal, what else besides the rotors do you need? Are the calipers different, are the pads different? - Is there a different caliper carrier bracket - to move the caliper outwards?
George
Old Apr 20, 2010 | 01:38 PM
Mafioso's Avatar
I think its just the carrier bracket if I understood one of his posts in here. it moves the caliper out.
The part numbers on the calipers apprear to be the same. in the NAPA catalogs.
(I work for Genuine Parts Co.) so I have access to many many catalogs.
Old Apr 20, 2010 | 07:32 PM
Caesar's Avatar
HI,
good thread!
I need to change my Breaks! I need all rotors!
I want to order them, because I get them cheaper then my service garage..
I got an offer for ABS(name of the brand) rotors 320mm front and 286mm rear... I would get them + the pads for € 390 (about 530$)
do they fit my 2002 STR?
I somewhere read, it needs 355mm... I'm confused..
I also found this rotors! very cheap! all 4 Brembo max just € 180,-- can it be? Do they fit?
Old Apr 21, 2010 | 02:29 AM
  #28
JagV8's Avatar
You need to find out whether you have the Brembo brakes, as the rotors & pads depend on that. This topic comes up quite often so use Search to find out what you want to know.
Old Apr 21, 2010 | 04:04 AM
Caesar's Avatar
HI,
sorry that I ask, but english is not my native language, so its sometimes hard for me to use the search function!
Who can I find out, if they are Brembo, and which diameter? It's not in the manual... right?
Old Apr 21, 2010 | 04:32 AM
  #30
JagV8's Avatar
No problem. But a search on:
Brembo
would likely work
The best way: any jag dealer can tell you.
If you post your vehicle details (year, etc) and last 6 positions of the VIN someone can probably figure it out.
Old Apr 21, 2010 | 07:16 AM
  #31
Caesar's Avatar
Hi JagV8!
Thanks a lot!
Its an STR 11/2002
The VIN is: SAJAA03SX21M61557
Greetz from Vienna
Paul
Old Apr 21, 2010 | 07:22 AM
  #32
JagV8's Avatar
That should be a 2002.5MY car and I'd expect it to have Brembo brakes. Front 365mm x 32mm (vented), rear 300mm x 15mm (solid) - but I've seen the rears claimed as 330mm so check those!
Old Apr 21, 2010 | 07:52 AM
  #33
Caesar's Avatar
So just with a measuring tape?from side to side of the rotor?
Old Apr 21, 2010 | 09:40 AM
  #34
Caesar's Avatar
So should I order 365mm and 300mm?
Greetz
Old Apr 21, 2010 | 09:43 AM
  #35
Mafioso's Avatar
Greetz
Not before you measure the rotors. No use getting the wrong parts.
Old Apr 21, 2010 | 09:46 AM
  #36
Caesar's Avatar
HI,
The Type of the STR is: CCX/YAB2/5LLLL
Old Apr 21, 2010 | 10:32 AM
  #37
Caesar's Avatar
HI,
Unforunately, I just can messure them with a ruler, cause I'm in the office right now..
But, messured from outside of the tires, it seems that they are biger then 320 respectively 300...
Isn't there a way to check it with the VIN?
Greetz
Old Apr 21, 2010 | 10:39 AM
  #38
Caesar's Avatar
HI,
I hust heard, that there exists a electronic catalogue, where u can find them with the VIN! Does anyone have this one??
It's very urgent!!
Thanks a lot!
Old Apr 21, 2010 | 11:07 AM
  #39
JagV8's Avatar
Call a dealer, then!
Old May 24, 2010 | 02:10 AM
  #40
acorey's Avatar
if the brmbos are do able i m dedfinitely consider doing them
