brakes
Old May 25, 2015 | 06:36 PM
christymc1973's Avatar
Default brakes
My husband and I just replaced the driver side rear wheel bearing. I know there is an easier way to do this, but we had to remove the half shaft to get the job done (damage done by previous owner). The car is repaired but now we need to put brake fluid in the car's brake system. The brakes were applied when the caliper was off and the brake piston came all the way out and leaked fluid. How do I replace the missing brake fluid
Old May 26, 2015 | 02:11 AM
NBCat's Avatar
You can download the JTIS Workshop Manual from this forum, but since the braking system is so critical for your safety and the safety of others on the road, you may want to consider having the system bled by a competent Jaguar specialist.
If you want to bleed the braking system yourself, begin with the RH rear wheel and then to the LH rear wheel next, finishing with the LH front caliper. Monitor the fluid level in the master cylinder reservoir and use only DOT4 fluid from a sealed container.
Perform a search of this forum as there are threads about bleeding the braking system.
PMKimpton
Aug 3, 2019 08:22 PM
flyrr100
Sep 29, 2015 03:47 PM
xjrjag
Sep 24, 2015 10:08 PM
wannajag
Sep 22, 2015 08:29 PM
Jefro
Sep 15, 2015 01:44 PM
