Broken HID lights
Old Jul 15, 2008 | 06:25 AM
KAZsam's Avatar
Default RE: Broken HID lights
Unfortunetly the *******s know this is a problem with the 03 STR but will not do a recal on them. It is a safety issue. But they make a fortune on the repair because from what I have read its a little plastic piece that keeps breaking.
Old Jul 15, 2008 | 12:13 PM
Jaguarnaut's Avatar
Is it still under warranty!!!
There is a fix someone posted on the forum somewhere!! Try finding it.
Old Jul 18, 2008 | 02:23 AM
HP774's Avatar
These links point to different solutions:
https://www.jaguarforums.com/m_43066..._3/key_/tm.htm
https://www.jaguarforums.com/m_36713/tm.htm
You can also block the movement of the headlight internals with the plastic hose which is on top of the assembly by fitting it inside.
I repaired mine with the aluminium block, they were fixed position unitl now but recently Jag have cleared the error fault on the motors and it works perfect.
Herve
Old Aug 13, 2008 | 11:28 AM
badmojo's Avatar
Same problem here. The little ball was broken off of the leveling slide. I took the lens off of the assembly and made a new piece out of nylon exactly like the old one. Everything works just like stock except I'm sure it will last way longer!! Headlights are not covered by the SE warranty. I called Jaguar.
Old Aug 13, 2008 | 01:40 PM
MidGaSTR's Avatar
Does anyone know where I could get a Factory Service Manual for problems like these? Mine aren't broken but could use some adjusting.
Old Aug 19, 2008 | 10:11 PM
momo's Avatar
ORIGINAL: MidGaSTR
Ebay, that is where I got mine.
Jpav27
Jul 31, 2022 06:43 AM
redrover41
23
Sep 25, 2015 01:33 PM
avern1
Sep 8, 2015 06:25 PM
afterburner1
General Tech Help
Sep 7, 2015 08:43 PM
XCrossWindsX
Sep 5, 2015 10:58 PM
