Can someone tell me what Airbag error Code that flashing ?
Old Jun 22, 2012 | 08:15 AM
cel2620xl's Avatar
Default Can someone tell me what Airbag error Code that flashing ?
HI....Can someone tell me what Airbag error Code that flashing ? i recorded a video of the number of flashes that being presenting. There one long flash then seven flash, Then it repeat. please look at the video and leave a your comment.
Thank you
Rick
Old Jun 22, 2012 | 08:41 AM
Rick,
I've had this annoying phenomenon on my XK8 for a few weeks now. Co-incidentally it's the same blink code of [1 + 7] flashes repeated three times before settling to a constant AirBag warning light.
On the XK8 this indicates a fault with one of the passenger sensors. The S-Type experts should be able to confirm if your model uses the same blink codes.
Old Jun 22, 2012 | 08:57 AM
JagV8's Avatar
From the codes for restraints in JTIS (free in the FAQs), that's passenger seat weight sensing fault either in CAN circuit or pressure sensor circuit
A bad connection (under seat I think) is typically the trouble, see previous threads / JTIS for where / what you're looking for.
Old Jun 22, 2012 | 08:58 AM
Here is the info, good luck. As Jag V8 says check the connections first.
File Type: pdf
Old Jun 25, 2012 | 05:30 PM
newtcopa's Avatar
my xk8 flashes five times, followed by two. I have no idea.
Old Jun 25, 2012 | 06:25 PM
A group of 5 flashes then 2 flashes indicates Flash Code 52. Code 52 = Front safety belt buckle or seat track position switch fault.
In order to find more detail on tis fault, you'd need to have the DTC's read. The AirBag ones are Bxxxx codes and it takes the Dealer equipment or something like AutoEnginuity to read them.
Old Jun 26, 2012 | 08:17 AM
JagV8's Avatar
The flash codes are in the codes PDF (either body or chassis) in JTIS. Just hunt through to find them.
Bcrary3
Feb 21, 2023 04:29 AM
Jpav27
Jul 31, 2022 06:43 AM
Johnken
Sep 15, 2015 05:46 PM
tonyforman
Sep 10, 2015 07:23 PM
mrplow58
Sep 9, 2015 11:27 AM
