Car locks, then unlocks
Old May 9, 2021 | 09:25 PM
Joe Gandalf's Avatar
Default Car locks, then unlocks
Sorry if this has already been asked, but the search feature won't let me narrow down my question.
Tonight, my wife's 2007 S type decided to refuse to remain locked. When I try to lock it (from inside or out) the locks activate, then they unlock a couple of seconds later. Checked doors - all are closed solidly. The same thing happens when we drive it: the car locks the doors, then they unlock automatically.
Ideas?
Old May 10, 2021 | 01:59 AM
joycesjag's Avatar
One of your lock actuators needs replaced. Many threads on the subject.
Goto search button, select "advanced", type "lock actuator", scroll down to "S Type", click "search".
Old May 10, 2021 | 09:22 AM
S-Type Owner's Avatar
Joe: Activate the locking function and look to see which locking tab "kicks back" to the unlocked position first; that lock will be your culprit...
Old May 10, 2021 | 12:46 PM
Thanks! It seems to be the front passenger door. One odd thing, though: if I'm inside and I press the lock "button" on the passenger door, everything locks OK. Well, not exactly - I still hear the "labored" sound of the actuator within that door. But the doors only remain locked with this method, not with the fob, not with trying to lock using the key in the driver's door, and not when I push the driver's side door lock button. Go figure!
Joe
Old May 11, 2021 | 11:46 PM
scottjh9's Avatar
I have had to replace all 4 of mine over the last 4 years. The rears are harder because of the opera window. The front is pretty straight forward. Pull the door panel off and go from there. One tip. The outside handle trim has a nut that you access from inside. The other side has a pinch together plastic push pin. Also from the inside
chuckjag
Jun 30, 2021 10:17 AM
David.rowley
Aug 14, 2017 05:51 PM
Faja
May 19, 2015 11:21 AM
RudyF6
Oct 5, 2011 06:25 PM
coventryfan
Dec 31, 2010 03:54 PM
