Car surges even though off Gas!!
Old Mar 22, 2013 | 03:21 PM
jsupstarz's Avatar
Default Car surges even though off Gas!!
this post is for a friend with an 04' "r".
Car was fine only with a long running cruise control failure (fault). So he was driving and he said the he took foot off the gas and the car kept going like he was on the gas so he shut the car off in gear now it is in limp mode and showing like 5 codes including cylinder 2 misfire and cat code and maf code. I know the codes could be from shutting the car off in gear. Any suggestions beside battery reset, what could cause this surging forward even though off gas?
Old Mar 22, 2013 | 04:09 PM
abonano's Avatar
Check battery first...
Old Mar 22, 2013 | 04:12 PM
JagV8's Avatar
Sticking throttle maybe? Would throw codes and likely get very upset. I suppose clear codes and see which one(s) flag first.
Any (engine) mods on the car?
A real possibility is a failing battery as it is needed even when driving.
Old Mar 22, 2013 | 09:00 PM
bfsgross's Avatar
The STR is a drive by wire throttle body. Did your friend happen to shroom at the time of the alleged unprovoked surge?
Old Mar 22, 2013 | 09:02 PM
bfsgross's Avatar
Default Medical
It's a medical question.
Old Mar 23, 2013 | 12:48 PM
clubairth1's Avatar
Community Influencer
Check the floor mat. It sounds dumb but it's easy to do.
Old Mar 23, 2013 | 01:50 PM
bfsgross's Avatar
Lol! Clubairth, you're a genius.
Old Mar 26, 2013 | 01:48 PM
jsupstarz's Avatar
shroom? bfgross. Don't know what that means. But I told him check the battery first, and reset it. I won't know the outcome, it was my car. And no modifications. Someone did mention something about possibly throttle body issue. But doubt it with 7 random codes. But I could b wrong
Old Mar 26, 2013 | 08:42 PM
bfsgross's Avatar
Lol, mushrooms...as in hallucinogens. Can't see that a stud
Ch
K throttle body could cause this except for some internal mechanical issue. Remember years ago when Audi had similar issues that caused crashes etc.?
Old Jun 15, 2013 | 05:40 AM
BigMike001's Avatar
I have a 2000 XK8 and I've had the similar thing occur. Driving along at low speed 20-40 kph) and the engine climbs to about 3000 RPM without contact on the accelerator. It settles down and the issue passes after a couple of minutes. This occurred a couple of times. I am still trying to resolve it.
Recently, the engine has been cyclically running up/slowing to idle at startup.
Old Jun 15, 2013 | 08:19 AM
JagV8's Avatar
Which engine? Auto/manual? Etc...
Sounds like an air leak. Get cheap OBD tool and report LTFTs at idle & 2500rpm, parked.
fast40driver
Apr 19, 2024 07:24 AM
Stoney85
Jun 10, 2021 09:14 PM
Stoney85
Australia - Queensland
Jun 7, 2021 11:49 PM
SingBlueSilver
Aug 27, 2015 02:20 PM
Vector
US Lower Atlantic
Aug 26, 2015 05:36 AM
