Check engine light- parkbrake failure, dsc fault, gearbox fault... and more
Old Sep 4, 2013 | 09:27 PM
  #101
howie713's Avatar
Originally Posted by ldillard
Update: Dealer got back with me today with the news... the bad news is, it is the throttle body sensor. The good news is, it is covered under warranty... Can't wait to get her back...
Have you got it back? If im not mistaken one of the codes that was thrown when my car had the battery issue was the Throttle body. Glad its under warranty and nothing comes out of your pocket. Keep us updated
Old Sep 5, 2013 | 01:48 PM
  #102
ldillard's Avatar
The dealer stated that only one code was thrown: P2135
Old Oct 21, 2013 | 02:30 PM
  #103
TomSTR05's Avatar
I just had same problems yesterday.I got in limp mode,check engine light came up and RMP 1100 at idle,turning off/on ignition help but after some time of driving limp mode coming back.Car shows :
-Engine system fault
-DSC not available
-Park brake fault
-Cruise not available
I connected my OBDII reader and it shows P2135 code:
-Throttler/Pedal position sensor/switch "A"/"B" voltage correlation
So what I need to do to resolve this problem? Get new battery or TB sensor?
Why Jag dealer changed TB sensor under warranty? Do you had extended warranty?
Old Oct 21, 2013 | 05:34 PM
  #104
jaguarxfv8's Avatar
Default battery // cables
Hi tomstr05, I had the same problem and just like you I thought it was my throttle sensor or the throttle in itself so I replace all this and the problem was still the same.
so replacing the entire throttle and sensors can be very very expensive so before you do that I suggest you check the cables connection and clean all of them. if this doesn't solve your problem you should check your battery and replace it even if the voltage his enough.
I have a 2009 jaguar xf supercharged (prenium luxury) and replacing the battery solve my problem so you should try that it's less expensive to start there beleive me ! I spend a whole lot of money on this problem to finally spend 450$ on a Bosch s6 battery.
Old Oct 21, 2013 | 05:35 PM
  #105
jaguarxfv8's Avatar
Old Oct 21, 2013 | 09:11 PM
  #106
TomSTR05's Avatar
Thank you jaguarxfv8 !! I'll try to clean TB,connections around and seal it.If it still occurs I'll change battery.
Old Oct 22, 2013 | 11:39 AM
  #107
howie713's Avatar
-DSC not available
-Park brake fault
The BEST thing I could recommend without having to spend any money and find the problem is to put your battery on a charging system. When its fully charged see if the car is having the same Engine, DSC, Park, cruise fault. I went through a lot of trouble shooting the individual codes. Before I decided to replace the battery. First thing you are suppose to do when troubleshooting any electrical issue is be sure you have a fully charged (good) battery and check fuses.
By charging your batter for a 3-4 hours you can see if the faults come back. When they don't that means your battery is starting to loose its ability to hold a charge and you need a new one.
toronadomike
Jan 22, 2026 10:13 PM
D.K
Dec 10, 2023 02:05 AM
Sprayall
May 30, 2021 08:13 AM
Sprayall
Sep 3, 2015 07:49 PM
pnwrs2000
Sep 3, 2015 11:55 AM
