Climate Control Issue
Old Jun 29, 2009 | 06:19 PM
JohnBurns's Avatar
Not sure whether this might help - but will post just in case it might. My A/C was intermittantly blowing hot air - the only way I could get cold air back was to turn thermostat to highest setting - or stop the engine, let set about 30 seconds and restart the engine. Jag dealer topped freon - then replaced Climate Control Module - before the following solved the situation:
"Found evap temp sensor was stuck reading one temp and would not fluctuate with temperature demand. Replaced evap temp sensor.
1 - XR83729 Sensor-Evaporator."
Since turning the thermostat setting to the extreme highest temp solved my problem temporarily, maybe your situation might be somewhat related?
Old Jun 30, 2009 | 02:06 AM
JagV8's Avatar
Please post the locations of the sensor and its connector (if not next to it).
Also, with it disconnected what does the a/c do? (Max heat? Max cold? Something else?)
Which engine do you have and do you know if that affects the type or location of the sensor?
Any pics whould be helpful.
Old Jul 4, 2009 | 04:33 PM
patrick12's Avatar
Sorry, my english is not the best....
Where is the "evap core drain"?
Can you maybe marked it here on this photo, please? :
http://s7b.directupload.net/file/d/1...3b4jmq_jpg.htm
Old Jul 4, 2009 | 10:28 PM
Thermo's Avatar
Veteran: Navy
Patrick, the evaporator core drain is actually inside the passenger compartment. To access it, you need to gain access to the ventilation system. Then, at the bottom of the ventilation system, there will be a drain line. This line runs through the firewall and then makes a 90 degree turn and drains to the ground. If I remember right, it will be in the corner near the passenger feet.
If you are dealing with a mildew type of smell, then you can remove the inlet filter for the ventilation system and then spray some Lysol down the intake and it will drain all the way to the evaporator core drain, getting rid of the blockage.
Old Jul 5, 2009 | 02:35 AM
patrick12's Avatar
Thank you thermo!
But i make a mistake and post this quastion in s-type thread, i need this info for the x-type...is there maybe a instruction on JTIS? i cannot found it inside this software.
Old Jul 5, 2009 | 06:48 AM
Thermo's Avatar
Veteran: Navy
Patrick, the evaporator core drain is going to be in roughly the same area. My experience with the JTIS is that it contains relatively little information on the X-type as compared to the other models. But, if you do the Lysol trick, it works on the X-Types also. I personally use a special air wand that I made that I can insert into the vent duct and I run it along the bottom of the box till I feel the drain hole. Then I give it a quick burst of air and that is normally enough to clear the plug.
Old Jul 5, 2009 | 10:38 AM
patrick12's Avatar
Edit........
Old Jul 5, 2009 | 03:02 PM
patrick12's Avatar
you mean remove the "pollen filter"? or which filter you mean with "inlet filter"? and then spray lysol in the way inside the passenger compartment?
& which lysol product you mean, what is the excactly name?
Thank you, Patrick
Old Jul 5, 2009 | 03:06 PM
patrick12's Avatar
Thank you, Patrick
Old Jul 5, 2009 | 04:09 PM
Thermo's Avatar
Veteran: Navy
Patrick, the filter in question is the one that is buried under the cowl at the base of the windshield. Some people call it an inlet filter, some call it a pollen filter.
As for the Lysol product, I am talking about is the "All Purpose Cleaner with Bleach" in the spray bottle or you can use the concentrated cleaner in the pour bottle. Either will work. if you use the concentrate stuff, then you will need to dilute it down say 50/50 with water and then spray it into the ventilation system through the pollen filter opening. If you think you have sprayed enough, spray a little more. It isn't going to hurt anything. Just the first time you use the A/C, let the system run for a minute or so with the windows open to vent any smells. The Lysol will also kill any mold that is in the drain tube, allowing the evaporator drain pan to drain, getting rid of the moist smell you can get some times.
Old Jul 6, 2009 | 02:28 AM
patrick12's Avatar
Thank you for the patience, thermo!
99xk8guy
May 28, 2024 09:36 PM
JarodL
Mar 7, 2024 01:39 AM
XJsc-guy
Sep 25, 2015 11:09 AM
tberg
Sep 7, 2015 07:32 AM
carelm
Sep 5, 2015 01:13 AM
