Clutch bleeding issue
Old Oct 7, 2024 | 10:35 PM
Krsone5791's Avatar
Default Clutch bleeding issue
Hey everyone. I just got done installing the engine and trans in my 03 S type 3.0. New clutch flywheel and slave as well. Parts came new in box with the car which had a blown engine.
I’ve got the access off and hose hooked up to bleeder screw, I assume is that long pipe hexagonal damper I believe they call it sticking out from the slave? I usually reverse bleed the systems and have success on my own. This time no dice. Fluid is falling back out but not much seems to be going in and of course pedal has no pressure. Should I try to gravity bleed or buy some kind of pump pressurized bleeder? Any help is appreciated.
oxendine
Sep 7, 2022 07:34 PM
JagDavid
E type ( XK-E )
Dec 1, 2021 05:18 PM
bobanddoug
Jul 20, 2017 04:17 PM
xtype62
Jul 20, 2016 12:17 PM
parkgate
Nov 11, 2009 12:01 PM
