Codes p0300, p0301,03 and 05.
Old Dec 1, 2012 | 11:05 AM
Mariobarreiro's Avatar
Default Codes p0300, p0301,03 and 05.
Need help trying to figure out what to replace first? Plugs, coils, sensor? 2005 s type v6
Old Dec 1, 2012 | 12:23 PM
Jon89's Avatar
Misfiring codes on the V6 models are often caused by the two factory Intake Maniford Tuner Valve O-rings failing and allowing oil to seep out of the IMT valves. Search this forum using the phrase "IMT valve O-ring leaks" and you'll have plenty of reading to do. Then, wipe the bottom of your IMT valves with a clean white paper napkin. If fresh oil shows up on the napkin, you have likely found the source of your codes. New O-rings are an inexpensive and relatively easy DIY fix....
Old Dec 2, 2012 | 08:52 AM
Great, I will check itnout immediately. Thank you very much
philwarner
Oct 4, 2024 01:37 PM
philwarner
25
Jun 26, 2021 05:43 AM
bdboyle
Sep 16, 2019 05:58 PM
JCam
Oct 23, 2016 08:27 PM
KarimPA
Sep 27, 2015 08:46 AM
